Old 08-24-2020, 03:18 PM   #1
prizmracer
Drives: 2018 Subaru BRZ 50th anniversary
Kenwood dnx997xr install questions
Hello All,
Long time lurker first time questioner.
I just mostly installed a new kenwood head unit. I have a 2018 BRZ 50th anniversary (I believe its a premium). I had a few loose ends I’m trying to tie up. If anyone could help I would appreciate it.
1. Do I need to connect the starlink wire? I’m not sure I ever clicked that icon in 2 years of having the stock head unit.
2. Is there anyway to keep the stock GPS antenna? I’m not sure if there is an adapter available. I’m also not sure there is any benefit to using the stock over the new one.
3. Basically the same question but with the Satellite radio. I’m guessing I need a receiver. So the stock unit must have had the xm receiver built in?
Thank you!
prizmracer is offline   Reply With Quote
Old 08-31-2020, 01:46 PM   #2
prizmracer
Originally Posted by prizmracer View Post
Hello All,
Thank you!
Here is what I ended up doing:
1. I gave up on Starlink, the last vestige of my highly flawed subaru stock headunit is gone. Doesn't seem to make any difference as starlink funstionality was basically no existent in the 2018 subaru anyway.
2. Yes you can kee the stock GPS antenna with the toyota gps retention kit. From idatalink
3. Same as above. I did need to buy a new siriusxm decoder
NRG Harness Bar install questions fizzymike Cosmetic Modification (Interior/Exterior/Lighting) 4 03-07-2018 08:09 AM
2017 BRZ Install Kenwood DNX893S 007BRZ Electronics | Audio | NAV | Infotainment 1 08-10-2017 03:40 AM
Kenwood DDX630WBT Toyota-spec head unit w/ nav install in US GSX-R35 Electronics | Audio | NAV | Infotainment 17 05-26-2015 03:37 PM
Kenwood CMOS-210 Backup Camera Install TSY Electronics | Audio | NAV | Infotainment 34 12-10-2014 01:18 PM
Planning out my Kenwood install KRAZYK Electronics | Audio | NAV | Infotainment 1 07-19-2012 09:24 PM
