Old 08-23-2020, 12:53 AM   #1
Jp8802
Drives: Toyota 86 GTS
I put wrong fuel in 86 gts
Hey guys, I own an 86 gts, 2 yrs old now.
I live in Sydney Australia. Today I accidentally filled the car with roughly 5 litres of 94 ethanol e10. I quickly realised and stopped, and filled up the car with 98 octane. My question is... do I need to get the petrol drained from the car?
The car was empty when I first started filling up.
I am concerned with the injectors
Jp8802 is offline   Reply With Quote
The Following User Says Thank You to Jp8802 For This Useful Post:
humfrz (08-23-2020)
Old 08-23-2020, 12:56 AM   #2
mariooo86
Drives: Scion frs
you should be okay since it was a small amount, just keep trying to dilute the gas with higher octane
mariooo86 is offline   Reply With Quote
Old 08-23-2020, 01:06 AM   #3
Jp8802
Thanks for letting me know. I have 90km trip tomorrow, and once done I will fill up the car again with 98 to dilute it. I tried checking online but it only says up to 2017 model is compatible.
Old 08-23-2020, 02:02 AM   #4
100% ok. If you check your manual you will see that 98 is recommended but 94 is required. You can even use 91 now and then with no ill effects other than a drop in performance.
DarkPira7e (08-23-2020), JesseG (08-24-2020)
Old 08-23-2020, 02:05 AM   #5
Kaotic Lazagna
Drives: GR Corolla
Probably should try to avoid driving it hard until you use up all the fuel or have mixed in enough premium in to actually have a 98 in the tank just to be safe. I'm sure the computer is compensating for the lower octane, but it doesn't hurt to play it safe.
Old 08-23-2020, 02:13 AM   #6
Read my post above. It is the same as us using 91 octane and will not harm the car in any way.
Old 08-23-2020, 02:16 AM   #7
Kaotic Lazagna
Drives: GR Corolla
Doesn't it say that using lower grade fuels can cause knocking?
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
JesseG (08-24-2020)
Old 08-23-2020, 02:21 AM   #8
The manual says minimum 91. His 94 is our 91. It is a total non issue. Even the drop in performance is almost non existent for street driving.
We can run 89 for brief periods without harm as well but I wouldn’t use it all the time and the drop in performance is noticeable.
There are many people that can’t even get anything more than 91.
JesseG (08-24-2020), soundman98 (08-23-2020)
Old 08-23-2020, 02:25 AM   #9
humfrz
Welcome to our forum, there, Jp8802 -
Your car will be OK, not to worry.
Just pay attention next time -
Old 08-23-2020, 02:31 AM   #10
humfrz
Kaotic Lazagna, you have been around long enough to know about that. Damn, iffen your short term memory is that bad - refresh it - look it up.
Oh, wait - maybe you are just trolling ol @Tcoat -
Old 08-23-2020, 04:34 AM   #11
Kaotic Lazagna
Drives: GR Corolla
I assumed their 94 was our 87. I'm sure that what ever he got is better than the 91 we get in California
The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post:
JesseG (08-24-2020), Tcoat (08-23-2020)
Old 08-23-2020, 04:35 AM   #12
Kaotic Lazagna
Drives: GR Corolla
Wait, what am I missing. I wasn't trolling this time.
humfrz (08-23-2020), Tcoat (08-23-2020)
Old 08-23-2020, 04:54 AM   #13
JD001
JD001's Avatar
Drives: Subaru BRZ
I would be worried if you poured diesel into the tank.. Petrol grades can be variable so no great shakes if you go up or down on octane levels..
The Following 2 Users Say Thank You to JD001 For This Useful Post:
Old 08-23-2020, 10:56 AM   #14
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
As has been already said, you'll be fine- ECUs are wildly intelligent.
You wouldn't believe the variances in the fuel you're getting, but you don't need to worry about it; the ECU has your back. As long as it's not diesel or water..
The Following User Says Thank You to DarkPira7e For This Useful Post:
JesseG (08-24-2020)
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 09:40 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Audio/Visual, Electronics, Infotainment, NAV 4 07-16-2016 06:43 PM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 06:21 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
Wrong Fuel Hawx AUSTRALIA 22 12-11-2011 06:08 PM
