Old 08-15-2020, 10:56 PM   #1
moolucky
Drives: 2017 Subaru BRZ
Gramlights 57Pro refurb help
Picked up a set of used Gram Lights 57Pro. Looking for some help/advice on how to refurb the lip on these. Tried metal polish. Not sure what to call the spider-webbing, is the clear coat corroding?
From what limited information I could find via google, I think I have to strip or wet sand the lip and apply a new clear coat? Anyone have any experience, knowledge, recommendations? Thanks in advance!
*please don't mind the gap
moolucky is offline   Reply With Quote
Old 08-16-2020, 12:56 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The coating is coming off, you won't restore it without sanding it all down and polishing/re-painting
Old 08-16-2020, 01:09 PM   #3
moolucky
Thanks! Guess I got my work cut out for me
Old 08-16-2020, 01:59 PM   #4
ls1ac
ls1ac's Avatar
The clearcoat on the silver polished aluminum is failing. This is comin in areas with salted roads or from using strong cleaners on the wheels. the gray is oxidized aluminum.
It will be hard to strip the clearcoat from the polished area and not from the gold. Using an abrasive course enough to cut the clearcoat but not make re polishing the aluminum difficult will take a lot of time.
Consider a chrome type paint, clean, buff, and coat.
Yes it can be done correctly, remove the tires protect the gold and take your time. The fact that the gold runs around the whole inner rim is going to be the hard part. Re polishing into the crevice all around the rim, not fun.
gram lights 57pro
Ray's gramlights transcends freidlytoyotafrs Wheels and Tires 4 12-08-2019 07:51 AM
Gramlights 57Valkyrie shadoken Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 10-03-2016 10:32 AM
Want to trade Gramlights eddieEndo Wheels and Tires 1 03-14-2015 09:27 PM
Ray's GramLights 57FXX Ray_32 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 11-18-2013 07:39 PM
GramLights ? Anyone got some on 86 ? rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-20-2012 05:22 PM
