Old 08-09-2012, 03:06 PM   #1
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Technical - Sorta: Roll cage design
So another thread went a little OT with roll cage design. Let's see some of your previous/current cages for your race car(s) and design design pros and cons of what we see.
Also, let's use this thread to discuss FRS/BRZ specific rollcage design information.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-09-2012, 03:07 PM   #2
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
And I'll start, here's the chump car cage:
Cage was built to meet LeMons, ChumpCar, SCCA and NASA requirements (ie, built to the strongest requirements of each). Seat is mounted to the cage, not the car, and uses a slider system with reinforced pins to allow for adjustment. This car is used for 7-24 hour long races so adjustable was desired to allow different driver sizes, not that we ever actually adjust it...
Thoughts on the design?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-09-2012, 03:23 PM   #3
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
FWIW, wasn't the FRS/BRZ dash designed in such a way that it didn't require cutting to install a roll cage? I recall reading that in some of the media during launch.
TomR
ABQautoxer is offline   Reply With Quote
Old 08-09-2012, 03:26 PM   #4
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You definately have to cut if you want the bars forward as much as possible.. if you like Cusco death cages (or any bolt in cage) you'll have to live with the bars in front of the dash.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-12-2012, 06:48 PM   #5
icemang17
Drives: Scion FR-S/ Subaru BRZ
cage design is highly dependant on two things:
1: The race series you plan on racing with requirements
2: The inherent strength-stiffness of the body
Many cars have fairly weak bodies....Many M3's that I race with break all kinds of body parts due to the chassis flex at high G loads....Mustangs are really poor in this area too.....
I don't know how strong-weak the FRS-BRZ platform is, but I would guess its on the weaker end of the spectrum given its light weight.....
If you have a less stiff bodied platform then you build extra reinforcements into the cage to stiffen it up....and pretty much all touring car based racers have cages designed to increase stiffness......
The advantage to a stiff body is using a lighter cage to save overall weight, but of course the stronger body probably is heavier to start with....
A simple test is jacking up 1 front or rear wheel..... when the wheel you are lifting comes off the ground, how close is the opposite side wheel (if there was no droop)....really stiff cars can lift the wheels from the OTHER end....
icemang17 is offline   Reply With Quote
Roll cage (Stealth Inc.) Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 12-16-2013 11:51 AM
Roll stiffness: Springs vs anti-roll bars? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-24-2012 05:44 PM
OptionJDM - Cusco Roll Cage OptionJDM Interior Parts (Incl. Lighting) 3 07-18-2012 11:22 AM
Proper Roll Cage CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 1 04-12-2010 03:51 PM
Ae86 roll cage in initial d? CyberFormula Off-Topic Lounge [WARNING: NO POLITICS] 8 03-13-2010 11:23 PM
