CANADA Canada
Old 07-24-2020, 12:57 PM   #1
mabviper
Drives: WRB BRZ
Arrow SPDA - Beginner friendly track day CTMP DDT Aug 8, 2020
SPDA is having another beginner friendly track day in Aug 8! Unlike the previous track day in June, we're finally able to accept novices for some coaching. If you have any questions, let me know
Yes, you read that right, the Touge is BAAAAACK!!! For those that have been around for awhile, you'll remember the ATTS Touge series where we ran a ladder system in a unique competition which pits 2 drivers against each other. The DDT is modified using cones to simulate the narrow roads in the Japanese mountains. We simulate narrow bridges and blind corners.
The objective is for each driver to get to their finish line first.
Here's how we do it. We setup 2 start finish lines on the main strait of the DDT approx 50 meters apart. Each of you line up at your respective start / finish lines. When the green flag drops, both of you accelerate as fast as you can and drive the modified ddt. Don't worry if you get too close to the car in front (20 meters) we flag you provide space.
The objective for the front car is to increase the gap between the cars, the objective of the car behind is to close the gap. The first one back to their finish line WINS that round, it's best 2 out of 3 and we switch cars around, back goes to front, and front goes to back and you get to do it again!!
The schedule for the day will be:
Open Lapping from 9:00 until 12:00 (by grouping, TBD)
Alligator Lapping during Lunch time
Open Lapping from 1:00 - 3:15
Touge from 3:15 until 5:00
Safety is number 1, Covid rules are in effect.
Maximum 4 crew members / car
Spaces will be limited.
Beginners are welcome and In car instruction will be available during this event. Back to normal, Nope. We'll be pairing coaches with students, and we will have sanitizers available, and it's highly recommended that everyone use them.
When social distancing is not possible, masks are mandatory.
Registration is open!!! https://spda-online.ca/spda_custom/a..._vbAttsReg.php
mabviper is offline   Reply With Quote
Old 07-27-2020, 05:17 PM   #2
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
I'm gonna be there! Time to break off more rust!
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 07-28-2020, 10:14 AM   #3
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
Provided that my pads and fluid cross the ocean in time, I'll be there!
JBezugs is offline   Reply With Quote
Old 07-28-2020, 08:58 PM   #4
Jordanwolf
Rice King
Jordanwolf's Avatar
This is really cool and sounds a lot like 'Best MOTORing' Touge.
Also, your link is dead. Brings me to a "File not found".
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 07-29-2020, 10:53 AM   #5
JBezugs
Good Job Subaru!
JBezugs's Avatar
Here's the fixed link: https://spda-online.ca/spda_custom/a..._vbAttsReg.php
Old 07-29-2020, 12:34 PM   #6
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
Noob question here...How hard is a track day on the braking system (pads and rotors)? I have the 2020 TS with the Brembo setup.
SUSPECT_BRZ is offline   Reply With Quote
Old 07-29-2020, 01:11 PM   #7
Frost
Frost's Avatar
DDT is particularly rough on pads especially if you're a newbie. Make sure you have fresh brake fluid and fresh pads (ideally track pads or full streets) before attempting.
If you plan on tracking and daily-ing the car, Jordan and Will Parsons can you give you some great advice for pads.
If you plan on ONLY tracking, well, that's easy - slap on some Carbotech XP10s and squeaaaaal like a bus!
Old 07-29-2020, 01:33 PM   #8
mabviper
Drives: WRB BRZ
Thanks for the fix
Old 07-29-2020, 01:54 PM   #9
mabviper
Drives: WRB BRZ
Personally, if you're new to track days, I'd drive what you have.
DDT is pretty hard to brakes but if you're only trying it out, I don't see any reason to change your brake fluids and brake pads. Just be conscious of what the car is telling you during your sessions. Brakes getting softer? Ease up on hard braking and let the system cool down. We coaches tell new students to smooth out your braking anyways cause it's not fun bobbing helmet heads throughout the session, lol.
After your first track day, once you know what needs to be addressed, make the adjustments. A good suggestion is to get new brake fluids and brake pads. But racing brake fluids absorb more moisture than regular fluids so it should be changed regularly. I run RBF600 and flush every spring. I would also suggest Ferodo DS2500s when starting out but the occasionally squeaks might annoy you.
Old 07-30-2020, 09:07 AM   #10
Frost
Frost's Avatar
Oh I forgot to mention that in car instructing will be allowed again so be sure to take on an instructor!
Old 07-30-2020, 11:14 AM   #11
SUSPECT_BRZ
Thank you all for the valuable information. I knew this was going to be somewhat of an expensive hobby
Old 07-30-2020, 12:58 PM   #12
Jordanwolf
Rice King
Jordanwolf's Avatar
Worth every penny.
I'm under some different circumstances this year or else I'd probably go to this. Might be doing some AutoX though.
Glorious Honda.
SPDA ATTS September 7, 2019 @CTMP DDT mabviper CANADA 1 08-28-2019 01:38 AM
SPDA - Barrie Subaru Charity Track Day (ATTS) - CTMP DDT, June 1, 2019 mabviper CANADA 11 05-29-2019 01:59 AM
SPDA ATTS - Beginner Friendly Lapping Days - Sept 9th mabviper CANADA 29 09-06-2018 10:31 AM
Lapping July 12th CTMP DDT - SPDA wparsons CANADA 164 09-21-2015 11:53 AM
Beginner Friendly Lapping Day at the new Mosport DDT track : September 07, 2014 7thgear CANADA 95 09-20-2014 06:21 PM
