| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: Subaru BRZ 2013 unlimited
I apologize in advance, as I'm not too knowledgeable with cars just yet. So forgive me if I leave out crucial information on this issue. But im having a problem in passing my smog for my 2013 BRZ limited. I've taken it like 3 times, and every time I take it to get the smog. They connect the OBD2 and it loses connection with the control module they tell me. And it keeps failing over that. The code it reads is U0155. And after all my lights flash on my dashboard. I've heard the ECU might not work well. I've heard that the dealer has to do an update on my ECU. But I've brought it up to my local subaru dealer and they dont even consider it. Im not sure what to do. I just got the car, and among this pandemic, all I really want is to be able to register it haha. If anybody has some knowledge or perhaps a lead on this. I'd deeply appreciate it. Thank you in advance.
Be Kind
Drives: 2020 86
From the interwebs:
"Code U0155 is typically caused by one of the following:
EDIT: Scratch that, a quick search: https://www.ft86club.com/forums/showthread.php?t=18511 EDIT 2: Or maybe a new battery LOL: https://www.ft86club.com/forums/showthread.php?t=141112
Thanks! I tried changing the battery. And whenever I go back to get the smog. It still reads that code on their OBDII. And just seems lock all my dashboard lights for a few miles. Ill look into the CAN Bus. Because I cant get my tags until I pass that smog.
Sent from my SM-G981U using Tapatalk |
Drives: 2020 GMC Canyon Denali Diesel
Does it read this code on other OBDII tools?
If no; a: the testing center has an issue with their OBDII reader b: The OBDII port in your car has a loose pin, use an OBDII extender cable https://www.amazon.com/s?k=obdii+ext...nb_sb_ss_i_7_6 If yes; You have a problem in the CANbus, likely a loose pin/broken wire in a harness connector somewhere.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
| Swapped my instrument cluster face w/ Indicator's Graphics Panel ver. I | Pointmutation | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 07-02-2019 10:35 AM |
| Single DIN Instrument Cluster | Aussie | DIY (Do-It-Yourself) Guides | 0 | 04-01-2018 06:44 PM |
| Removing panel above instrument cluster | inio | DIY (Do-It-Yourself) Guides | 3 | 08-09-2015 02:34 PM |
| F/S: FR-S instrument cluster | MissDeb | Audio/Visual, Electronics, Infotainment, NAV | 5 | 04-08-2014 04:02 PM |
| WTB: FRS instrument cluster | jabbajaw99 | Interior Parts (Incl. Lighting) | 3 | 02-14-2013 01:31 PM |
