Old 07-18-2020, 03:25 AM   #1
chd1287
Drives: Prospective
JDM STI Pinks with SACHS Dampers
Are JDM STI pink springs (orange and white paint marks) compatible with my 17 USDM PP BRZ with the SACHS dampers? I assumed these would work so I snagged a set, but after doing some searching on here, I'm not certain they work well with the SACHS dampers.
chd1287 is offline   Reply With Quote
Old 07-18-2020, 03:27 AM   #2
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
They will absolutely work. Go for it and enjoy.
BlueWhelan is offline   Reply With Quote
The Following User Says Thank You to BlueWhelan For This Useful Post:
norcalpb (07-19-2020)
Old 07-18-2020, 03:43 AM   #3
gpvecchi
gpvecchi's Avatar
I have them on my Toyota Sachs, that are different from Subaru. Happy, but front becames a little too bouncy for my tastes.
gpvecchi is offline   Reply With Quote
Old 07-18-2020, 07:39 AM   #4
chd1287
Drives: Prospective
Awesome. Thanks for the input.
Old 07-18-2020, 08:39 AM   #5
N_Raged
Drives: 2019 BRZ Sport-Tech RS
The pairing of damping rate with spring rate might not be perfect as Subaru intended but it will work. Similar to if you were to put aftermarket lowering springs on your stock shocks - who knows what exact damping rates those springs were designed for.
As @gpvecchi beautifully summarized in this post, the Sachs dampers change every few years - possibly from minor changes in damping rates to continuously improve the car. But there's no data to support this so we can only assume.
The Sachs dampers on the tS claimed to be "tuned by STi" but they're not even branded STi anywhere on them.
Until someone compares a yellow Sachs with a purple Sachs back to back on the same spring and car for example, we won't know how great the difference in damping rates are.
N_Raged is offline   Reply With Quote
The Following User Says Thank You to N_Raged For This Useful Post:
gpvecchi (07-18-2020)
2017+ BRZ PP Sachs Dampers kashmir Brakes, Suspension, Chassis 2 08-27-2019 10:52 AM
LF sachs dampers jhalagian Canada Classifieds 0 07-10-2019 11:31 AM
LF: 2017+ Sachs dampers Spaceweed Canada Classifieds 3 04-04-2019 10:57 AM
Review: RCE Yellows on BRZ PP Sachs Dampers mjanmohammad Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 04-17-2018 12:11 PM
Sachs Dampers on a Monogram? Yardjass Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-29-2017 05:47 AM
