Old 07-16-2020, 07:39 PM   #1
Bianc_203
Bianc_203's Avatar
Drives: 2016 Scion FR-S
Question Question about buying parts
Hello,
I just wanted to double check before buying parts for my 2013 FR-S and was wondering if I were to purchase parts from Subaru (searched 2013 BRZ) if the BRZ parts would be compatible with my FR-S?
I know that Scion is under Toyota and I can specially search for FR-S parts on their website, but the part I’m looking for is cheaper when going through Subaru and I just wanted to make sure if a BRZ’s engine parts would work on an FR-S of the same year.
The part I’m looking at is the engine variable valve timing solenoid (VVT) if that helps.
Bianc_203 is offline   Reply With Quote
Old 07-16-2020, 07:49 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Originally Posted by Bianc_203 View Post
Hello,
Yes, it is the same between models. I'm not sure if the year matters though.
Old 07-16-2020, 07:58 PM   #3
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
It’ll work. The cars underneath are identical.
Only a select handful of cosmetic parts (specifically related to the front bumpers) won’t work, along with a few other misc. items.
TylerLieberman is offline   Reply With Quote
Old 07-16-2020, 08:42 PM   #4
Spuds
The Dictater
Spuds's Avatar
Suspension was always a bit different.
Old 07-16-2020, 08:44 PM   #5
Just the shocks and springs. The rest is the same.
Old 07-16-2020, 08:47 PM   #6
Bianc_203
Bianc_203's Avatar
Thank you both!
Old 07-16-2020, 08:52 PM   #7
TylerLieberman
Drives: '24 GR86
If we’re gonna nitpick, then sure. But they are interchangeable between vehicles, which is what was obviously meant in response to the original question.
Badges were also different. As were center caps, airbag cover, seats, dash trim, gauge cluster etc.
Old 07-17-2020, 09:21 AM   #8
Spuds
The Dictater
Spuds's Avatar
I just wanted to clarify the blanket statement where someone reading this might infer that you can go grab a stock Subaru damper to replace a damaged stock Scion damper and it would have the same parameters.
BUYING PARTS JoeyMarch Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2015 03:05 PM
buying used parts dmitri93 Scion FR-S / Toyota 86 GT86 General Forum 2 07-18-2014 07:27 AM
Buying computer parts compared to suspension parts Anomie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 12-09-2013 11:56 AM
Quick question about buying TRD parts JLMtm Scion FR-S / Toyota 86 GT86 General Forum 1 03-25-2013 07:40 PM
Buying Parts brzzz Scion FR-S / Toyota 86 GT86 General Forum 3 10-04-2012 12:15 AM
