Old 07-15-2020, 03:51 PM   #1
Brenton86
Drives: 2.0 high
2013 Toyota 86 gearbox concern
Hi guys. I'm about to purchase a 2013 high spec 86 with 68000kms on it. When shifting to 2nd gear at normal/low rpm, the gear seems to slightly grind, or not shift in smoothly as the other gears. Is this a normal thing with this year model? The owner did raise the issue to toyota at 40000kms but they said that its normal and not a fault.
Also the valve spring recall was done at 60000. After 8000kms is it safe to assume things are all okay?
Appreciate your urgent advice.
Thank you
Brenton86 is offline   Reply With Quote
Old 07-15-2020, 04:06 PM   #2
Veloist
Veloist's Avatar
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
It’s normal especially when the car is cold but mostly any time it’s slower speeds and the car is coasting during the shift (like going downhill). This happened with my 2016 BRZ and is still happening on my 2020 BRZ. Like I said, it occurs almost all the time when I first start it up whether it’s morning or late in the day.
Veloist is offline   Reply With Quote
Old 07-15-2020, 04:19 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
In my experience, my car never liked shifting into a higher gear at an already low RPM. I target my shifts at 2700RPM or above.
Change your transmission fluid and give it 500 miles to see if it helps
Old 07-15-2020, 06:40 PM   #4
Veloist
Veloist's Avatar
Here you go
https://www.ft86club.com/forums/showthread.php?t=31929
Old 07-16-2020, 01:04 AM   #5
humfrz
Thank you
Welcome to the group -
The rough shifting into second is normal for most people.
You car should be OK that many miles after the recall work.
I suggest you just practice the timing on the 1-2 shift, when you are able to do it smoothly without using the clutch, you'll know you have the timing right -
Old 07-16-2020, 02:41 AM   #6
Brenton86
Drives: 2.0 high
Thanks for the info and reassurance guys. I'm going forward with the finance process. I would probably be asking a lot of questions as I'm learning about the 86 now lol.
Once I get the car I will have toyota change the gearbox and diff oil with the engine oil change. Super excited for my first rear wheel drive car.
Old 07-16-2020, 02:46 AM   #7
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Old 07-16-2020, 06:08 AM   #8
sneaky_pete
Drives: MY14 86 GTS Manual Velocity Orange
1st to 2nd shift issue is pretty much normal when the car is cold. once the gearbox is properly warm (after 15 minutes of driving) you shouldn't have a problem.
sneaky_pete is offline   Reply With Quote
Old 07-16-2020, 03:14 PM   #9
humfrz
What you en on me fer ....??
Old 07-16-2020, 03:20 PM   #10
Spuds
The Dictater
Spuds's Avatar
You know why. Telling folks to shift without the clutch...
Old 07-16-2020, 04:57 PM   #11
humfrz
OK, you have a point, most of them have enough problems shifting using the clutch -
However, learning to shift up the gears, not using the clutch, is a good exercise to learn and get the feel of how a MT works.
Also, if your clutch goes out, you can usually make your way home (just don't stop). Also, unless you explode the clutch, then maybe not.
Hell, I shift up the gears without using the clutch many times.
Old 07-16-2020, 04:59 PM   #12
Spuds
The Dictater
Spuds's Avatar
Old 07-16-2020, 05:09 PM   #13
humfrz
Well, a is better than a
Old 07-16-2020, 06:32 PM   #14
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
The twins are happiest when they are being driven quickly. I don’t mean driving like a maniac, but when your inputs are quick. I’ve experienced a notchy 1-2 shift many times while putting around, never when I’m driving faster.
So the faster you drive the twins the better they feel. It’s pretty cool when you think about it. The opposite of a relaxed cruiser type of car, or even muscle car. In regards to driver inputs, not all out speed. Tons of cars are faster than the twins.
JesseG is offline   Reply With Quote
HOLINGER SG INDIRECT 6 SPEED SEQUENTIAL GEARBOX PACKAGE - 2013+ FT86. Yay or Nay? VictorKassil Engine, Exhaust, Transmission 17 09-19-2017 03:14 AM
Concern about CF theft? JoeC Cosmetic Modification (Interior/Exterior/Lighting) 19 02-29-2016 02:06 PM
Grinding gearbox, Toyota Sweden do not want to listen :( Fricke Issues | Warranty | Recalls / TSB 8 10-09-2014 01:00 PM
Toyota Camatte 57s - 2013 Toyota Toy show BigRedDog Off-Topic Lounge [WARNING: NO POLITICS] 2 06-13-2013 09:39 AM
gearbox/shifting concern Kosmos Issues | Warranty | Recalls / TSB 9 05-10-2013 08:53 PM
