Drives: '15 Halo Scion FRS, 1999 Saturn SC2
Clutch, TOB, or other?
I have a 2015 Scion FR-S, bought new, now with 154,000 miles. I have/had a 30-miles each way commute, driving ~30K miles per year, hitting 150K in March. Since March, just 4000 miles due to the zombie apocalypse.
The engagement point for the clutch seems to suddenly be much closer to the floorboards. This seemed to have pretty sudden onset, and appears to be getting worse with (light) continued use. My previous vehicle was a Saturn SC2, where the first clutch lasted 160K miles, and the second 200K (replaced at 360K miles). I'm assuming this is the clutch failing, but could it be just the TOB, or something simpler/cheaper than a clutch replacement? What should I have my guy look for? If I replace the clutch, I plan to go OEM.
2015 Halo Scion FR-S 6MT new w/TRD exhaust, cold air intake, quick shifter, sway bars, lowering springs, & brake pads. Since then, TRD door braces, strut tower bar, & battery tie-down, Motul fluids in trans/diff & brakes, GrimmSpeed master cylinder brace, Stoptech stainless brakelines, OpenFlash Header 3 w/overpipe, OpenFlash Tablet on E85
#2 | |
![]() With 154,000 miles on your clutch system, it may very well have used up itself and needs to be replaced. However, before you do that you may wish to bleed the clutch system and put in new fluid. Then you may consider adjusting the clutch. |
^^ Yeah if you haven't bled the clutch system that would be the first thing I'd do before throwing a few hundred dollars at it.
| Brand *NEW* still sealed Clutch Masters FX-300 complete Clutch - SOLD | JohnnieBoy | Transmission and Driveline | 5 | 12-15-2018 08:32 AM |
| SOLD: OEM Clutch, Pressure Plate, Clutch Fork and Pivot, Exedy TOB | zc06_kisstherain | Transmission and Driveline | 3 | 10-17-2018 10:31 PM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 12:06 PM |
