Old 07-07-2020, 09:10 PM   #1
Stu L Tissimus
Stu L Tissimus's Avatar
Drives: MT GB BRZ Limited
Feasibility of figuring out current gear, clutch pos over CAN/OBD2?
(EDIT: RESOLVED)
Hi there! First off, a disclaimer - this is not exactly about tuning, but there's enough overlap that I think this is the best forum to ask about it in.
Okay - so as a little hobbyist project, I want to build a cheap, stupid device that will show me "if you downshift from CURRENT_GEAR to CURRENT_GEAR-1, what should your target RPM be?" Basically, a little helper for rev-matching.
Current plan is:
- ELM327 OBD2 reader communicating over BT to...
- an ESP32 (or some such hobbyist chip) displaying on a cheap display
The logic would be pretty simple on the ESP32. A quick and dirty pseudocode representation:
Code:
def main():
    while True:
        if(was previously in gear, and we just clutched out):
            desired_downshift_rpm = calculate_downshift_rpm(last_observed_gear, last_observed_rpm)
            update_display(desired_downshift_rpm)
            # probably some timeout
        last_observed_gear = OBD2.read_gear()
        last_observed_rpm = OBD2.read_rpm()
def calculate_downshift_rpm(
    last_observed_gear: int,
    last_observed_rpm: int,
    gear_ratios: Dict[int, float],
    last_ratio = gear_ratios[last_observed_gear]
    next_ratio = gear_ratios[last_observed_gear - 1 /* excluding first gear */]
    return last_observed_rpm / last_ratio * next_ratio
def test():
    # Going from 1000rpm @ 2nd -> 1600 rpm @ 1st
    assert calculate_downshift_rpm(
        last_observed_gear=2,
        last_observed_rpm=1000,
        gear_ratios=hardcoded_gear_ratios
    ) roughly_equals 1657
hardcoded_gear_ratios = {
    1: 3.626,
    2: 2.188,
    # etc etc
    5: 1.000,
    6: 0.767,
So, finally, here's my question.
I've messed around with OBD2 readers on my phone, and it can definitely read RPM (and the latency is surprisingly not bad), but I haven't seen if there are PIDs for:
- what's my current gear? (manual transmission if it counts)
- what's the clutch pedal position?
すばらしい。いや、スバルしい。
Stu L Tissimus is offline   Reply With Quote
Old 07-08-2020, 12:13 AM   #2
Compelica
Compelica's Avatar
Drives: 86 GT
Techstream has a number of information that is shown, however I'm not sure whether those are communicated via OBD2 PIDs or via some other means. I've did some tinkering in the past by sniffing the communication between the ECU and Techstream to identify the PID and replaying the transmits and responses in hex values to understand how they are derived.
I'm sure it's possible on our cars (it was a long time ago, I've lost all the software) but if those values you're looking for are available in Techstream, chances that you would be able to pull it from your OBD2 reader.
Compelica is offline   Reply With Quote
Old 07-08-2020, 02:04 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
As there is no sensor (except maybe reverse, as rear camera & backup lights switch on immediately when putting in reverse gear) for gear position and even for car dash gear indication itself position gets calculated only after gear switch and letting out clutch pedal (and it gets calculated wrong for guys with different FD, if they don't also adjust calculation ratios in ecu tune), with lag, from engine rpm readings & wheel speed sensors, and even for clutch IIRC there was just sensor if clutch pedal is on or off (for keyless start sake i guess), i don't think you'll be able to get needed readings from twins stock sensors.
Maybe some custom aftermarket sensors can be added to clutch and gearbox, but have no info on those.
Old 07-08-2020, 08:18 AM   #4
steve99
As above the ECU calcualtes the gear from rpm and speed data. There is no gear sensor.
Note you can get auto blip rev matching on these cars with ecutek tunes, ie it blips throttle for you on downshift, and full throttle upshift, all in software
Old 07-08-2020, 10:04 AM   #5
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
You have speed, RPM, and clutch position in OBD. That should be all you need to figure out the current gear.
Oh and this :
First Gear 3.626
Second Gear 2.188
Third Gear 1.541
Fourth Gear 1.213
Fifth Gear 1.000
Sixth Gear 0.767
Reverse 3.437
Final Drive 4.100
ref: https://www.caranddriver.com/subaru/...rz_2013/350874
Old 07-08-2020, 11:56 AM   #6
Stu L Tissimus
Thanks guys!
I recognize the Ecutek can auto-blip for me, but I'm doing this more for the fun of building it
すばらしい。いや、スバルしい。
Old 07-08-2020, 01:01 PM   #7
Yoshoobaroo
TRACKBREAD
Originally Posted by Stu L Tissimus View Post
Thanks guys!
I really like the idea!
Old 07-08-2020, 06:50 PM   #8
7c8
You won't be able to request the calculated gear over OBD2, but you can access it under the regular CAN bus:
Offset: 6 bytes
Length: 4 bits
Mask: 0x0F (i.e. you only care about the 4 least significant bits on that byte)
These 4 bits match the gear display, and reads 7 (0b0111) when nothing is displayed, between shifts, neutral, etc..
Obviously you could compare vehicle speed vs. engine speed, which would be faster I think. You can also get those off the CAN bus, which is quicker and less intrusive than over OBD2.
Vehicle speed:
Offset: 0 bytes
Length: 2 bytes (little endian)
Multiplier: 0.05747 for kph, 0.3571019137 for mph
Engine speed:
Offset: 2 bytes
Mask: 0x3FFF
EDIT: You can see how well comparing vehicle speed vs. engine speed works here: https://streamable.com/sqk9h8
It's much faster than using the gear data on the CAN bus because you don't necessarily have to wait for clutch out like the ECU does in the car.
7c8 is offline   Reply With Quote
Old 07-17-2020, 08:11 PM   #9
Stu L Tissimus
(I finished a super hacky quick-and-dirty version here!)
すばらしい。いや、スバルしい。
Old 07-17-2020, 08:21 PM   #10
Yoshoobaroo
TRACKBREAD
Sweet!
Old 07-22-2020, 12:15 PM   #11
pallen
pallen's Avatar
Drives: 2017 Toyota 86
Somewhat related, I've noticed the gear indicator on the gauge cluster sometimes isn't there and occasionally is even wrong - it may say 4 when I'm in 5th. Is this normal? Its not like I actually need this, but I found it odd.
pallen is offline   Reply With Quote
Old 07-23-2020, 09:18 AM   #12
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
If you've changed wheel diameter from stock or changed the FD then this would be your issue.
Dzmitry is offline   Reply With Quote
Old 07-23-2020, 09:22 AM   #13
pallen
pallen's Avatar
I have the stock 17" wheels.
What is FD? I feel like I know that abbreviation, but its escaping me at the moment...
Old 07-23-2020, 09:28 AM   #14
Dzmitry
Dzmitry's Avatar
Final drive. You did buy the vehicle used, do you happen to know if the seller ever replaced the FD?
Cruise control and current gear suddenly not working, but suddenly worked again btan219 Issues | Warranty | Recalls / TSB 2 06-30-2018 01:09 AM
Car will not go into gear after new clutch install?! Amartinez99 Engine, Exhaust, Transmission 15 01-15-2018 01:25 PM
is it ok to slip my clutch often in 2nd gear when my rpm is below 2k? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 88 06-17-2015 06:12 PM
clutch/gear box getting softer zERoTu Issues | Warranty | Recalls / TSB 3 06-05-2014 08:18 AM
Display current gear without clutch engaged? cfusionpm Scion FR-S / Toyota 86 GT86 General Forum 45 03-26-2013 04:08 PM
