Old 07-02-2020, 08:30 PM   #1
SON1C
SON1C's Avatar
Drives: 2015 Series Blue BRZ WRB
Exclamation Max camber with Subaru/Toyota Crash/Camber bolts?
Double checking, these are the correct part numbers 901000394 or Toyota/Scion part # SU003-02818
Can you safely run two in each side, to achieve more camber?
SON1C is offline   Reply With Quote
Old 07-02-2020, 09:49 PM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
With Camber bolts in the lower holes, the lower bolts now become crash bolts for the top holes. I got -1.9 deg camber both sides on the front with stock PP suspension.
dragoontwo is offline   Reply With Quote
Old 07-02-2020, 09:50 PM   #3
7 skulls
Drives: 2014 scion frs
Part numbers look correct. According to subaru, the bolts are reusable but the nuts are not. Nut #902380008. Stock subaru camber bolts (one per side) will give you -1 deg camber.
7 skulls is offline   Reply With Quote
Old 07-02-2020, 11:56 PM   #4
strat61caster
strat61caster's Avatar
No, the second bolt is the exact same as the camber bolt, swapping it for the factory part does not net any additional camber.
-1.1 maybe a bit more if you're lucky with one set of camber bolts.
https://www.ft86club.com/forums/showthread.php?t=103609
ineedyourdiddly
wparsons (07-03-2020)
Old 07-03-2020, 12:08 AM   #5
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Attached are the details. As other mentioned , you'll get a maximum of -1 deg camber.
Old 07-03-2020, 01:15 AM   #6
gpvecchi
gpvecchi's Avatar
Mine is just 0.6 mm with Subaru Camber bolts...
gpvecchi is offline   Reply With Quote
Old 07-03-2020, 01:29 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
mm? Isn't it toe that's measured in alternatively inches or mm aswell no just degrees/minutes, not camber?
Old 07-03-2020, 08:23 AM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Not sure why you measure camber in mm.
The manual says that these bolts can give a range of 0°± 45’ camber. If you had a stock camber of -15’, then you can get a max of -1°.
Old 07-03-2020, 04:32 PM   #9
gpvecchi
gpvecchi's Avatar
Sorry, I was in hurry, my camber went from stock 0 to around 0.5 degrees.
The Following User Says Thank You to gpvecchi For This Useful Post:
nikitopo (07-04-2020)
Old 07-16-2020, 04:19 PM   #10
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Double SPC camber bolt sizes;
Lower location is a 14mm bolt.
Upper location is a 16mm bolt.
I use both plus Peddars Offset Top Mounts (-.75).
All three combined achieve -2.75 front camber, without coil-overs. In my case Koni Yellows with TRD springs.
Alignment by Alex at Burning Rubber (Oakville, ON).
Muskoka800 is offline   Reply With Quote
Camber bolts or crash bolts for max spring perch clearance? norcalpb Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 01-29-2021 11:53 AM
OEM Camber Bolts (Crash Bolts - SU003-02818) dieseldan444 Brakes, Suspension, Chassis 2 07-12-2018 09:06 PM
Max camber on OE crash bolts?! warmwetness Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 09-11-2016 10:43 PM
DIY | Video Installing Camber Crash Bolts Dezoris DIY (Do-It-Yourself) Guides 24 09-06-2016 11:07 AM
Part Number for OEM crash (camber) bolts for FR-S? Rampage Tracking / Autocross / HPDE / Drifting 4 07-10-2013 11:14 PM
