Old 07-01-2020, 02:20 AM   #1
Nik33615
Nik33615's Avatar
Drives: 2013 FR-S MT
2020 86 A/C R134 or R1234 ?
Title says it all did the BRZ 86 switch to the newer r1234 yet? I am thinking of upgrading from my 2012 July model the new air will be easier to fix and works way better at idle.
Nik33615 is offline   Reply With Quote
Old 07-02-2020, 07:34 AM   #2
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
The most recent information I find online is from May 2019.
Appears Subaru models Made in USA are the Subarus with the newer refrigerant.
(https://macsworldwide.wordpress.com/...igerant-update)
{Let's make Honeywell and Dupont, aka Chemours happy, as they make the stuff}
ToySub1946 is offline   Reply With Quote
The Following 3 Users Say Thank You to ToySub1946 For This Useful Post:
dragoontwo (07-02-2020), Nik33615 (07-06-2020), sunami88 (07-02-2020)
Old 07-02-2020, 09:34 PM   #3
ToySub1946
ToySub1946's Avatar
Oops, I failed to show Toyota:
The Following User Says Thank You to ToySub1946 For This Useful Post:
Old 07-15-2020, 05:47 AM   #4
nicholasaallison
Drives: vw golf
It would be nice to modify these model vehicles.
nicholasaallison is offline   Reply With Quote
Old 07-15-2020, 09:45 AM   #5
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
If you knew(or could get from another Subaru model) the proper orifice size, and oil type needed, I don't see why you couldn't.
dragoontwo is offline   Reply With Quote
Old 05-09-2021, 09:07 AM   #6
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
I'm not sure what's giving you those ideas.
For one, 1234yf is a lot more expensive than 134a, 1234yf recovery/recharge equipment runs pretty slow, it takes about two or three times as long to recover and charge a car with 1234yf versus 134a (at least with the OTC/robinair equipment which is likely the most popular).
And from all the dodges and hondas I've had to deal with, I've not seen this increased idle performance.
The Following User Says Thank You to RZNT4R For This Useful Post:
jcw99 (05-09-2021)
Old 05-09-2021, 12:31 PM   #7
RZNT4R
Some further reading about 134a -> 1234yf
https://www.macsw.org/WEB/images/Mac...R-1234yf18.pdf
-Summary: Swapping a TXV system from 134a to 1234yf yields results ranging from no change to a slight decrease in performance. And right now the gas which allows this leap in performance (haha) costs over 6 times the price.
Keep in mind, 1234yf was never intended to be a better refrigerant from a cooling capacity standpoint, it was designed to be less disastrous for the environment than 134a while working at near 134a pressures to ease the transition.
ToySub1946 (05-09-2021)
2020 tS pricing (MD) Alistia Mid-Atlantic 25 03-05-2020 05:07 PM
2020 86 colors? AnalogMan Scion FR-S / Toyota 86 GT86 General Forum 12 10-09-2019 06:32 PM
2020 86 cys19 Scion FR-S / Toyota 86 GT86 General Forum 3 08-26-2019 03:40 PM
2020 BRZ tS? funwheeldrive BRZ First-Gen (2012+) — General Topics 114 08-26-2019 02:49 PM
