Drives: FRS
Was turbo tuned and now built engine and question on tune
So I had a stock FA20 and was turbo for about 13 months and now going built engine. I was on a conservative tune (9psi and doing 285whp on 93 and e85 10psi 315whp) I am swapping to same compression engine just a closed deck outfront motorsports, titanium retainers and valves only major change is to fluidamper and the rest just upgraded cooling mods and just new timing chains, tensioner, coilpacks and spark plugs.
I will break in engine soon and was wondering if need a whole new tune or can I break in with current tune and then once broken in get a full re-tune to go with built engine. Thanks, |
Drives: 2019 Toyota 86 TRD SE
Should probably ask your tuner this.
Drives: brz 2017 hksv2
use it
just use the most conservative of the 4 maps you have from your tune |
Drives: FRS
Ah shucks that sucks. I’d go with the post above. Use the most conservative map. I’m guess since the compression ratio is the same there shouldn’t be much of a difference but I’m no tuner. Good luck man.
Do you have control over your right foot?
Drive it. |
ProCrastinationConsultant
after no response for 8 business days, i'd find a different tuner.
Rust bucket enthusiast
If there's something amiss with the installation you may not know for some time, whereas if someone we're watching your datalogs with intent to re-tune, they would catch it.
It SHOULD be ok for break in, but there's no way to know without datalogging. Fight for your tuner's attention, it could be what saves this engine in the rare event that something IS wrong and you can't tell (fuel trims way lean due to slight exhaust leak at header for example) |
Drives: FRS
I am going to wait for his reply for another day or two and see what happens. If don’t hear back I am just going to go to local tuner.
#10 |
the answer will be that you can drive
you haven t change anything technically and if you want you xan post a log here you have to do it anyway, just drive gently |
| Thoughts on this built engine for my Turbo FRS | Conman | Engine, Exhaust, Transmission | 42 | 08-17-2019 01:53 PM |
| Whats my car worth? (Built engine, Turbo kit) | glorydays | FR-S / BRZ vs.... | 16 | 07-13-2019 08:55 AM |
| Built engine question | 86 driver | Engine, Exhaust, Transmission | 13 | 09-10-2015 11:16 PM |
| Worlds Fastest Turbo BRZ gets faster! Accelerated Performance Built - Visconti Tuned | Visconti | Forced Induction | 697 | 11-13-2013 06:18 PM |
| What is the best turbo for a fully built engine scion frs | SUB-ZERO | Forced Induction | 41 | 09-18-2013 06:41 PM |
