Old 06-19-2020, 09:48 PM   #1
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
Perrin Water Pump Pulley & Coil Packs
I have the following engine components for sale:
- Lightweight Perrin water pump pulley. Used condition, has a bit of gold overspray on it that can be removed. Significantly lighter than stock: $60
- OEM coil packs that ran fine on the car for 70K miles: $80
If you're interested in anything else in the full part out picture, please reach out for the following:
- Manual steering wheel with custom katana ito wrap has held up well to 30k miles: $100
- Hawk Street 5.0 brake pads with only 50 miles on them!: $180
- Perrin gurney flap which is used but in good condition; will not include hardware but you can find what you need: $70
- LED blinker lights for front headlight, these are incredibly bright: $20
- Pair of OEM BRZ daytime running lights (above fogs), have been converted to use spade connectors: $100
- Dragonball shift knob for automatic shifter: $10
- ATEQ QuickSet TPMS programmer, super easy to use for changing summer & tire wheels: $100
- Planted seat bracket, used and in good condition: $100
majixmatrix is offline   Reply With Quote
coil pack, oem, part out, perrin, pulley
Do I have bad coil packs or a failing DI pump? xkalelx Forced Induction 16 03-15-2016 01:56 PM
How to install a light weight water pump and alternator pulley. Mr. DIY (Do-It-Yourself) Guides 0 11-06-2014 03:11 PM
Raceseng | Water Pump Pulley Recall Raceseng Engine, Exhaust, Transmission 98 10-30-2014 04:46 PM
Go Fast Bits Water Pump Pulley Cracked reneezak90 Engine, Exhaust, Transmission 2 10-01-2014 07:02 AM
