Old 06-15-2020, 07:48 PM   #1
zberz
Drives: 2015 Lightning Red BRZ
Oops (Secondary O2)
Well, I fucked up while removing my stock headers by forgetting that I had a secondary O2 sensor. As I was trying to lower the headers, I felt binding on the passenger side, but it was too late. I scratched some of the wire shielding off, right at the sensor.
It's killing me because all of the wire is intact, it's just some shielding that's broken. I know this is an important part, and especially being mid-turbo install, I don't want to half-ass things. I just find it hard to accept that I need a new one, knowing that this one will function fine (for now). Moisture will be introduced eventually (I live in MD), and that is the concern.
I'm toying with the thought of covering it in Permatex Copper sealant. Good to 700 degrees and non-conductive. But, I also don't want to be cheap and half-ass something before a $1000 dyno session.
Thoughts? Any experience with something similar? Should I just bite the bullet and buy a new one?
Sent from my SM-G950U using Tapatalk
zberz is offline   Reply With Quote
Old 06-16-2020, 12:38 AM   #2
tomm.brz
Drives: brz 2017 hksv2
it is not important specially if you go turbo, it gets disabled
it s not even a real widerange sensor, just disable it on tune and you can even remove it 16
Old 06-17-2020, 06:41 AM   #3
ShawnP19
ShawnP19's Avatar
Drives: 2016 Series.HyperBlue BRZ
Honestly that doesn't look that bad. I see the insulation is cut but is the actual conductor knicked? Even then, it looks like some simple 3M electrical tape would fix it. Wrap the individual wires, then wrap them all together as a bundle. And as an extra measure against the elements you can get some flexible plastic conduit and trim a piece to fit. (It's slotted so it can just slip over the wires).
I would've said heatshrink but the size you need would require you lopping off one of the ends and reterminating. So, nah.
ShawnP19 is offline   Reply With Quote
Old 06-18-2020, 09:08 PM   #4
zberz
I guess I hadn't really thought about it, but with no cats, the secondary O2 is pretty useless. Still going to install it and let the tuner know I screwed it up, but I agree. Thanks!
Old 06-18-2020, 09:10 PM   #5
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
you can put some liquid electrical tape on it, then wrap it in more tape.
Old 06-18-2020, 09:32 PM   #6
zberz
Didn't know liquid electrical tape existed, but that's really good to know. After looking up the heat rating, 275 degrees might not be enough for an exhaust.
oops Boomerang Off-Topic Lounge [WARNING: NO POLITICS] 34 01-16-2020 08:51 PM
Oops never was a fan of paved roads so..HEH thebus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-06-2014 05:05 PM
Oops. BRZ on fire. Tuner to blame? russv Scion FR-S / Toyota 86 GT86 General Forum 21 09-10-2013 08:10 AM
Oops Toyota Australia nix AUSTRALIA 12 06-10-2012 04:14 AM
