Drives: 2016 BRZ Hikari
looking for a backup camera to work with my OEM stereo
2016 BRZ Hikari (Hyper Blue) with OEM headunit like the attached pic
Any suggestions on getting an aftermarket camera kit to work with this unit and also comes with wiring n everything? Thanks |
Drives: Scion 86 tS
This is what I use. Works pretty well.
https://www.amazon.com/gp/aw/d/B07H8...b_b_asin_title Might also need this to plug into your pre 2017 head unit. https://www.amazon.com/gp/aw/d/B01MT...b_b_asin_title |
#3 | |
However the camera says its 12V it works fine with you OEM DC supply? From what I read its only 6v supply. |
Drives: Scion 86 tS
Yep! The camera and the harness will work with just those things. At least it did for me in the FRS. It should be the same with the BRZ. There's going to be a red wire coming from the camera, you need to supply that with 12V. You can tap into pin 2 of the 28pin connector behind your head unit for 12V. You'll still need some way to tell your head unit that you're in reverse. I honestly forgot how I did this. I just remember tapping into a pink wire or something down by my left foot.
There's quite a few videos and threads on how to hook it all up. But those 2 things I sent you for sure you'll need. You might need some extra wire for that reverse signal. |
#5 | |
| Backup Camera input/recommendations for 2014 Monogram without factory Backup Camera | RedLeaderD4S | Electronics | Audio | NAV | Infotainment | 3 | 08-04-2017 08:32 PM |
| Backup Camera Kit Doesn't Work | Quentin! | Electronics | Audio | NAV | Infotainment | 4 | 08-08-2016 11:24 PM |
| SOLD - Rydeen Duo ZH07-150B Backup Camera and Rear Camera SVXdc Harness | NanDAssi | Audio/Visual, Electronics, Infotainment, NAV | 5 | 11-24-2015 05:06 PM |
| Backup camera | G8mou | Northern California | 28 | 01-08-2015 01:25 AM |
| Backup Camera | Raven23 | Electronics | Audio | NAV | Infotainment | 6 | 07-16-2014 02:50 PM |
