Drives: Scion FRS
Common Engine/Transmission issues after 100k
Hello,
Apologize if there is already a thread related to this. I bought my FRS a few weeks ago and it has over 100k miles on the bad boy. Clean title, no accidents reported and two owners... Just curious to see what issues ya'll have run into or if you have any tips for what to check on or look for after the 100k mark. Like I said, I apologize if there is a thread already about this subject.
Rust bucket enthusiast
Just typical maintenance. Spark plugs, serpentine belt, making sure the fluids are all properly cycled... Beyond that, I don't think there's anything specific to this platform/engine that sticks out. Yay for timing chain!
I would suggest replacing all fluids- oil, transmission, differential. Even if the seller says they did, you'll only know for sure if you do it. Check the serpentine belt for cracking, check all 4 tires for uneven wearing/balding. Address as necessary and enjoy! |
friendly
Drives: 17' 86
It's mostly the usual stuff as posted above. Also, want to make sure spark plugs were changed which can be a bear on this car. If the transmission is shifting smoothly you're pretty much golden.
Seek comfort in discomfort.
Drives: Scion FRS
Alright, all of that sounds pretty straight forward to me! I appreciate the quick reply.
I have 150k miles and nothing wrong with the engine and 6 speed manual transmission. This thing lasts longer than other Subaru’s, that’s for sure.
Check the maintenance schedule. That is about it.
Only "engine issue" I have is it seems to be getting progressively better gas mileage than when I first bought it 8 years and 160,000+ miles ago.
As others said, keep up the standard maintenance and you shouldn't have any issues. If you weren't given maintenance records probably worth making sure the next few are done on-time and complete. Also, @Steamy, there's a lot of good threads and information on here, but some that's a little "sky is falling" as well. What year is your FRS?
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
Drives: car
@Steamy
Flex from the transmission mount, if the car has done peel-outs and bogged deep. Mine was banging around at 90k miles and making it hard to shift. Put in a whiteline transmission insert and it fixed a lot of issues with drivetrain lash - and improved response. And also recently bought a new transmission mount to put in to freshen things up at 130k miles, should be crisp. Rear shift-stop deteriorating, gets boogered up and makes shifts into 1st, 3rd, 5th feel bad. This is fixed with the Perrin rear shift stop, part of the "positive shift kit" which also includes the above mentioned whiteline transmission insert. Throw-out bearing wear. On my 3rd TOB, the latest being a revised part which should last longer? Rear drivetrain lash from worn mounts. Banging differential. I'm hoping that whiteline inserts on the differential and subframe should tighten things up. Wheel studs shearing off one after another after ~4 years. I upgraded to ARP wheel studs. Alternator could have excessive wear depending on conditions. I've heard of a few premature alternator failures. Important because the electric power steering runs directly off the alternator. I'm going to test mine soon because it's something I'm concerned about. Last edited by radroach; 06-11-2020 at 11:19 PM. |
#9 | |
Drives: Scion FRS
#10 | |
Depending on your VIN, there is a valve spring recall that is discussed ad nauseum on here. If you don't know if you are impacted you could check it at the NTSB site here. That should also tell you if has been reported as completed on your vehicle. If it hasn't been done, I think most folks would suggest you not get it done. Since the car has over 130,000 miles on it its not likely you will have an issue. Technically, a later failure is covered by the recall anyway, although it may be problematic to prove what caused the failure. If you do decide to get it done, make sure the mechanic has done it before and that they have had no reported failures afterwards. I did have mine done early on at it has been fine. Others, as you will see on here, have not been as fortunate.
#11 | |
Drives: Scion FRS
| Consistent issues over 100K miles | fxo | BRZ First-Gen (2012+) — General Topics | 46 | 09-12-2019 08:31 PM |
| Is this a common BRZ manual transmission problem? | SamtheKorean | Engine, Exhaust, Transmission | 19 | 07-19-2019 06:27 PM |
| Common Suspension Issues | Nah | Issues | Warranty | Recalls / TSB | 1 | 03-28-2017 09:09 PM |
| Transmission Issues (AT) | RichardJ | Engine, Exhaust, Transmission | 1 | 03-24-2017 08:47 AM |
| Five Axis Spoiler Paint Issues? Common? | SHIFTER | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 07-04-2014 01:28 PM |
