Old 06-11-2020, 09:14 AM   #1
Chuckable
Drives: 2017 Toyota 86
CQuartz vs Avalon King
Anyone have experience with these? In particular ease of application and durability?
Have never used ceramic before, though I’ve detailed a few dozen cars. I’m located in a hot and humid climate so interested in flash time.
Any feedback is appreciated!
Chuckable is offline   Reply With Quote
Old 06-11-2020, 11:02 AM   #2
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I've used Cquartz but not Avalon king. It was easy to use and should last around 2 years depending on how it's cared for.
I've also used optimum gloss coat. It's currently on my car and used with hyper-seal as a dry-aid.
Consider grabbing Carpro reload with Cquartz(or the accompanying topper for Avalon king) as a maintenance product. It will keep the resin on the coating in peak condition.
Humid conditions you reference the shorter flash time.
I'd start by testing on a lower panel section first to see how it flashes.
Avalon king application instructions suggest a flash time from 1-5 minutes depending on temperature. In your case it'll be a short flash time around 1 minute.
https://avalonking.com/blog/how-to-a...ramic-coating/
Originally Posted by Avalon application instructions
#5 – Once you’ve applied the coating to the full section, let it sit between 1 to 5 minutes (based on the temperature range listed below). After the required wait time, you’ll proceed to the final phase of buffing.
Temperature Range
50-degrees F (10-degrees C)
60-degrees F (15-degrees C)
70 to 80 degrees F (20-25 degrees C)
Length of Time
4 to 5 minutes
2 to 3 minutes
1 minute
Cquartz UK 3.0 is around 2-4 minute flash time.
https://www.carpro-us.com/protection...-3-0-30ml-kit/
Originally Posted by Cquartz application tips
- If coating is applied thick then the coating will take longer to flash. If applied thin it will flash faster. Hot temps will cause it to flash faster, cold temps will cause it to flash slower. Air movement will cause it to flash faster.
- When it starts to flash you will see colors that will make the coating look like a rainbow or oil slick. You will see hints of blue, purple, red, and yellow.
Remove too soon and it will be oily with no grab to it when wiping. If you wipe off too soon it will not give the coating a chance to bond.
- Remove too late and it becomes hard to remove.
The time to remove is when you feel just a little push back or "grab" against your towel but it is not difficult to remove and it is no longer oily. It may leave some streaks at first but with the second wipe of a fresh clean side of the towel, the streaks should wipe off and the paint should be nice and clear.
If it becomes hard to remove, you can quickly go over it with more product and immediately remove it. Usually that is enough if you are just slightly slow on removing the excess product.
The Following User Says Thank You to RToyo86 For This Useful Post:
Chuckable (06-11-2020)
Old 06-11-2020, 12:17 PM   #3
Chuckable
Thank you for the thorough reply. I have been reading through the instructions and reviews, but it’s always good to hear real world results.
Old 06-12-2020, 12:06 PM   #4
HaXx
Drives: jrsc_brz
you can save a huge amount if you use devin niemelas discount if you decide to go avalon king. search him on youtube for the code, it cuts the price of one bottle in half i think. ive purchased avalon king before, im sure its no different from any other ceramic coat. unless you want to get the good good stuff that only authorized shops can get/install, think its call opticoat.
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 06-12-2020, 03:47 PM   #5
Chuckable
Appreciate that tip. I’m leaning toward CQuartz at this point but still looking at reviews.
2019 Toyota Avalon Spied For the First Time, Expect a Bolder Design gymratter Other Vehicles & General Automotive Discussions 6 08-05-2017 02:08 PM
A regular Avalon bdbx18 FR-S / BRZ vs.... 11 11-25-2015 01:20 PM
The king is dead, long live the king! Re~Mix Other Vehicles & General Automotive Discussions 8 10-08-2015 04:08 PM
Picking up my FRS ULTRAMARINE should I get cquartz? Elliryx Scion FR-S / Toyota 86 GT86 General Forum 22 08-25-2015 10:15 PM
CQuartz'd My Wheels switchlanez Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 03-09-2014 01:56 PM
