Old 06-04-2020, 08:49 PM   #1
johnnybaboon
Drives: 2013 Scion FRS
Sudden MPG drop
I bought my FRS in 2013 and for the first few years I was happy getting ~23 mpg almost all city driving. I calculated it myself after every refuel. One day it dropped to ~18 and has been the same ever since. After a couple years of this, I took it to the dealer and they used a scan tool and said everything was in range. I just fueled up yesterday and got 17 MPG on this tank and it's driving me crazy.
Is there an issue that wouldn't show up on the scan tool or something I should look into to figure this out?
Tires are aired to specs. I've gotten all recommended maintenance. Driving habits haven't changed.
Thanks for any suggestions.
johnnybaboon is offline   Reply With Quote
Old 06-04-2020, 09:01 PM   #2
alxtheoreo
alxtheoreo's Avatar
Has the intake air temperature (IAT) sensor been cleaned? Also, when was the last time the engine air filter was replaced? Finally, have you switched to a lower octane fuel?
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
alxtheoreo is offline   Reply With Quote
Old 06-04-2020, 09:06 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Maybe the traffic in where you're driving has changed significantly. Could be that you accidentally switched to kilometers instead of miles on your odometer.
Could be a culmination of things- low air pressure in the tires, super dirty air filter, along with the oil needing to be changed and your rear passenger side brake caliper dragging just a bit.
Or you are suddenly worse at math
DarkPira7e is online now   Reply With Quote
Old 06-04-2020, 10:16 PM   #4
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
How many miles on the odometer?
Time for new spark plugs?
LimitedSlip is offline   Reply With Quote
Old 06-05-2020, 12:32 AM   #5
johnnybaboon
The IAT sensor has probably only been cleaned if it was done as part of the scheduled maintenance package I bought. But I don't know for sure. Same for the engine air filter. Maybe the dealer has that on file and I can ask. I have always used 91 octane.
No change in traffic. Didn't switch to kilometers. Tires are aired to specs. Oil has been changed regularly. After one maintenance, they marked the air filter as "yellow" meaning it would need to be changed soon. I don't remember if that got done. I'll have to check that out.
Lmao it's hard to routinely mess up miles/gallons, but I'll start double checking.
46k miles on the odometer. Spark plugs were changed a year ago.
Thank you all for responding
Old 06-05-2020, 09:19 AM   #6
p1l0t
p1l0t's Avatar
Change your air filter! It's cheap, easy, and fun. If that doesn't fix it, spark plugs. You may also want to try bottle of fuel injector cleaner.
Old 06-05-2020, 09:54 AM   #7
When you change between MPH and KPH only the speedometer changes. All calculations for mileage stay in the original system.
Old 06-05-2020, 10:02 AM   #8
Busybee
Busybee's Avatar
Drives: GR86 Trueno Edition
Was the ~23 mpg same during winter and summer ?
I have a noticeable change between summer and winter. Did you check every fueling or from time to time.
Mazda 323F BA 1997 - Overseas
Mazda 323 BG 1994 - Sold
Mazda 323 BG 1991 - Sold
Busybee is offline   Reply With Quote
Old 06-05-2020, 11:21 AM   #9
There is a definite difference between winter and summer blend fuel. Here is the average by month for the history of my car. The dips occur consistently in the winter but 90% of my driving is the exact same route. That does not change per month.
Dadhawk is online now   Reply With Quote
Old 06-05-2020, 11:22 AM   #10
DarkPira7e
DarkPira7e's Avatar
Never knew that! Interesting. And I was tired, that would've given them way BETTER mileage
Old 06-05-2020, 11:28 AM   #11
Busybee
Busybee's Avatar
Looks like your average increased from 2013 to 2020. What was the change in 2019 and 2020 increasing the overall average ? Looks very nice
Old 06-05-2020, 11:53 AM   #12
p1l0t
p1l0t's Avatar
He drives like a...
Old 06-05-2020, 11:58 AM   #13
Honestly, not really sure but yes, my mileage has increased over the life of the car. The drive train is stock, and other than semi-standard maintenance has had nothing done to it.
The tires have been changed twice (I'm on my third set) but sets one and two are the same tires (see my owner's journal for details).
I expected it eventually to peak as the car went from stiff to running to aging state but so far at over 160K miles, that hasn't happened.
Driving habits haven't changed either, and as mentioned above, since this is my commuter (80 mile around trip per day) nearly all the miles are on the same road, and same time of day. There is only the occasional road trip. On weekends I drive a different car most the time.
Old 06-05-2020, 11:59 AM   #14
He drives like a...
Actually I don't. I'm first off the line (never been beat by a soccer mom), take most curves at twice the "recommended speed" and drive manual a good bit of the time.
The secret is my average speed falls right into the sweet spot of around 50MPH.
Sudden lean 17AFR, but then sudden rich 10AFR??? No codes D-VO Software Tuning 4 12-11-2019 12:17 AM
Sudden Power Loss / Hesitation and jerking under WOT Jesse36m3 Forced Induction 6 05-14-2018 09:59 PM
Sudden limp shifter feel. MWD Issues | Warranty | Recalls / TSB 6 11-06-2017 10:38 AM
about the car's sudden change in idling gustavowoltmann Off-Topic Lounge [WARNING: NO POLITICS] 1 10-19-2016 05:30 AM
Sudden high fuel trims - help please! cawith Issues | Warranty | Recalls / TSB 13 10-15-2015 04:30 PM
