Old 06-03-2020, 10:29 PM   #1
norcalpb
norcalpb's Avatar
OEM Audi A4 domelight vanity LED retrofit
I've had this mod for a few years now and I felt it was time to share. The twin's interior at night always felt too dark to me, I missed how my old Audi A4 had interior lighting that would like up all the aluminum interior trim pieces. So I swapped those LEDs over to my BRZ with fantastic results.
Preperation:
You will need to buy a used OEM domelight from the Audi A4, model years 2002-2008. I bought a 2003 domelight from eBay, but ultimately you will buy something similar to this:
I wish I had pictures of how I disassembled the Audi dome light, but it is extremely straight forward. Remove phillips heads screw to extract the LED module and disconnect the power/ground wires. The LED module is held in place by pressure or clips, but I can't remember. Very easy to remove:
You will end up with this:
I replaced the Audi connectors with pin style connectors from an old Invisicord cable I had laying around. The connectors look like this:
Place double sided tape behind the LED module (flat side, not resistor side):
Installation:
Remove domelight by inserting a screwdriver or other trim remover here and pry down to free the Subaru/Scion/Toyota domelight from it's mounting clips:
Disconnect the domelight power cable from its harness:
You will need to notch the exposed rectangle where the domelight sits to make room for the new LEDs (I did a really rushed job with a knife and sand paper, so I know people will do much better):
Cut a notch on the bottom of the twin's domelight so the light has a place to shine through. I tried drilling individual holes because that would be much cleaner, but messed up so I just drilled out a half-oval for the light to shine through. Once again, I think someone else could've done a much better job here:
Remove 3m tape backing on the LED module and adhere to the OEM twin's domelight. Amazingly, it fits right between the 2 Toyota mounting clips. What are the chances!
The lights shine through like this:
You will then need to disconnect the mirror power harness which is found just above the domelight power harness (Thank you @speedracer38 for the pictures:
This is the connector you will plug into:
Make sure that the clip is facing down when you install the newly installed pin connectors, but the red wire goes BOTTOM RIGHT and the green wire goes BOTTOM CENTER:
Finally, put everything back together taking care to not snag any wires.
Enjoy your new OEM Audi LED vanity light!
Old 06-08-2020, 07:34 AM   #2
Guest
Drives: 2017 BRZ PP
I did something similar.
Guest is offline   Reply With Quote
The Following User Says Thank You to Guest For This Useful Post:
norcalpb (06-09-2020)
<<< NEW Interior LEDs ~ FR-S + BRZ Domelight/Trunk/Packages (BRIGHTNESS OPTIONS)>>> KI_ZN6 Interior Parts (Incl. Lighting) 939 02-19-2016 12:02 AM
Vanity Plates Tomsterbrz BRZ First-Gen (2012+) — General Topics 72 03-29-2014 05:48 PM
Any Interest? Dual Color Domelight boredom.is.me Interior Parts (Incl. Lighting) 3 03-02-2014 05:22 AM
Dual Color Domelight boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 6 10-16-2013 01:23 PM
The Best and Brightest Domelight Available Acree Cosmetic Modification (Interior/Exterior/Lighting) 118 08-14-2013 08:20 AM
