Old 06-01-2020, 07:38 PM   #1
DoubleAKash
Drives: 2019 Subaru BRZ - JDL Turbo Kit
Suspension recommendation around the $2k mark
Hi All,
Another post haha but aside from the wheels and tires which I've picked out the next step for me is Coilovers. Wondering what recommendations some people have around the $2k range
I'm mainly going for street use and autocross eventually, but I want a bit more of a stiffer ride than the Stock PP. I do also plan on lowering the car about an inch or so on 18x8.5 wheels
Some of the recommendations and systems I've looked at:
Ohlins SUU MP22
Fortune Auto 500 series (6k front and 7k rear spring rate)
Cusco Kouki Coilovers Street Zero A
Bilstein B16 PSS
ST Suspension XTA Height, Rebound Adjustable Coilover Kit w/Top Mounts
MCA (but do they ship to the US??)
DoubleAKash is offline   Reply With Quote
Old 06-01-2020, 08:40 PM   #2
Chuckable
Drives: 2017 Toyota 86
Might want to add:
MCS (Motion Control Suspension)
RCE (RaceComp Engineering)
CSG-spec Teins
Chuckable is offline   Reply With Quote
The Following User Says Thank You to Chuckable For This Useful Post:
RToyo86 (10-05-2022)
Old 06-02-2020, 12:27 AM   #3
DoubleAKash
I don't know how many people are in NorthCal but has anyone had experience with Annex Suspension Group? They seem to be quite popular with the 86 Drive Challenge
https://annexsuspension.com/collecti...13891543138367
Old 06-02-2020, 12:47 AM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
There is a thread about it on here.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
DoubleAKash (06-02-2020)
Old 06-02-2020, 06:46 AM   #5
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Haven't tried myself, but I've only heard very few, but good reviews. They do look they part. Dont like them? Sell it to me for hlf price after haha jk, okay not really kidding lol
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Old 06-02-2020, 09:28 AM   #6
Racecomp Engineering
What kind of tires do you use and what size?
There are a couple good options under $2k but I would recommend budgeting for set up and a few supporting mods.
- Andrew
Old 06-02-2020, 10:11 AM   #7
HaXx
Drives: jrsc_brz
Essentially, forget what you have read on the internet and call Counterspace Garage, and call Racecomp Engineering. Talk to them over the phone, or start an email chain with them and ask questions and get a feel for what systems they say is right for you, spring rates, ride height etc, and price. they are not just salesmen, if you ask them a question about tires on here, they will answer, and they dont even sell tires.
i used to take down trees so i like to use this example: dont decide which tree company you want to come take down all your trees over the internet. I encourage people to get a minimum of 2 estimated from different tree companies (despite being partial to the one i work at). It is very likely there will be huge discrepancies in price to achieve the same end result.
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
The Following 4 Users Say Thank You to HaXx For This Useful Post:
CSG Mike (06-07-2020), DoubleAKash (06-02-2020), Pat (10-07-2022), wparsons (06-09-2020)
Old 06-02-2020, 10:13 AM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
For OP usage, coilovers are not strictly necessary.
I recently went to Bilstein B8s (B6s would also work) with Swift Spec R springs. Pretty great on the street, quite a bit stiffer than stock at 4.4 kg/mm front, 5.3 kg/mm rear, car is ~1.25" lower than stock. I'm also running Raceseng camber plates, which I had to have 6mm spring spacers machined for the fronts to prevent the front from being too low. Not necessary if you run factory strut isolators, or perhaps other camber plates...
Anyway this was a tremendous improvement for me vs. previous setup with Swift BRZ Sport springs with stock PP Sachs dampers and Raceseng plates. That setup had about zero bump travel up front Actually worked OK at the track but on the street it was murder... The Bilsteins have WAY more bump travel
fminicooper (10-06-2022)
Old 06-02-2020, 11:47 AM   #9
Tanstin
Tanstin's Avatar
Drives: 2013 Scion FRS
Not OP, but what made you choose Swift Spec R springs versus lets say, RCE Tarmacs or Yellows? Ive been really eyeing the Bilstein B6/B8's, and have been comparing spring combinations for a DD/Weekend warrior setup
Tanstin is offline   Reply With Quote
Old 06-02-2020, 12:13 PM   #10
DoubleAKash
- Andrew
I plan on using the Michelin Pilot Sport 4S in a 235/40/R18 in a 18x8.5 wheel size
Old 06-02-2020, 12:48 PM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
RCE options look really good as well. The lowering is a bit more reasonable for real-world.
The Following 3 Users Say Thank You to ZDan For This Useful Post:
Racecomp Engineering (06-02-2020), Tanstin (06-03-2020), wparsons (06-09-2020)
Old 06-02-2020, 02:34 PM   #12
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
OP, in my research, I am leaning towards RCE yellows and B6 for DD and spirited runs. I will not be autox or tracking it. If I was, I would consider coil overs from the various names mentioned above. I still think about coilovers, but some of my recent runs on some bumpy country roads with the stock suspension makes me think twice.
Ernest72 is offline   Reply With Quote
The Following 2 Users Say Thank You to Ernest72 For This Useful Post:
fminicooper (10-06-2022), Tanstin (06-03-2020)
Old 06-07-2020, 11:18 PM   #13
Unless you're running super sticky tires, check out the CSG spec Flex A. It's ~2x stiffer than stock in terms of spring rate, but actually ride smoother than stock. It's also got quite a few championship winning cars running them, so the pedigree is there.
Old 10-05-2022, 01:13 PM   #14
Swisher Seattle
Drives: 2017 BRZ LMT w/ performance Pkg
HKS HIPERMAX S is the best ever for 86
Swisher Seattle is offline   Reply With Quote
recommendation suspension alignment bridgetown1 Mid-Atlantic 2 01-20-2020 09:27 PM
Supercharger mark up dtrop Forced Induction 8 08-13-2015 02:37 PM
Poor 86 at 2:50 Mark Jason@DSG Scion FR-S / Toyota 86 GT86 General Forum 18 11-18-2014 01:04 PM
Nav - how to mark blockage? MysteryMachine Electronics | Audio | NAV | Infotainment 0 12-23-2013 05:59 PM
E85 400hp mark Fabron757 Forced Induction 26 06-20-2013 01:41 PM
