Old 05-30-2020, 03:21 PM   #1
GrabTheWheel
Drives: 16' BRZ
Titan 7 wheel install
I just tried to mount a set of 18x9.5 Titan 7's and it didn't go so well. I have ARP wheel studs that are 1.75" long which I believe is a bit longer than factory and 949 Racing lugs.
The studs don't seem anywhere near long enough to accommodate the wheels. Also once I get the wheel onto the studs it just seems to get stuck when it's halfway on. The holes are large enough for the studs but something is preventing me from pushing the wheels all the way onto the studs.
Any advice?
GrabTheWheel is offline   Reply With Quote
Old 05-30-2020, 04:01 PM   #2
Chuckable
Drives: 2017 Toyota 86
Have any pictures?
Chuckable is offline   Reply With Quote
Old 05-30-2020, 08:16 PM   #3
GrabTheWheel
Drives: 16' BRZ
Originally Posted by Chuckable View Post
Have any pictures?
I was being stupid and forgot to remove some little plastic pieces of the hubs from old 949 wheels. Got them on but the length of the studs has me a little nervous. Will probably switch to longer ARP studs before tracking. Was able to get about 8 to 9 turns by hand with the lugs. I counted how many lug threads were sticking out past each stud once torqued and counted 16 for the old setup and 18 for the new. For some reason looks like more. What's the general rule of thumb to be considered safe?
Old 05-31-2020, 01:05 AM   #4
dchan8
Drives: Toyota Celica
General rule for fasteners is that it has to engage the same amount as the diameter of the bolt
dchan8 is offline   Reply With Quote
Wheel Directory: Rota Titan 17x8.0 +42 jsc1234 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 47 06-09-2022 05:31 AM
steering wheel install help needed MachineHead DIY (Do-It-Yourself) Guides 6 02-03-2020 05:54 AM
Wheel Directory: Rota Titan 17x8.0 +45 stvrjs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 166 05-04-2018 09:35 PM
Wheel Directory: Rota Titan 17x9.0 +45 SpeedR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 05-20-2015 08:15 PM
Prova Steering Wheel Install RallySport Direct DIY (Do-It-Yourself) Guides 38 08-05-2014 12:42 PM
