Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 05-28-2020, 10:01 PM   #1
Feednamese
Drives: 86
STI Engine Mounts Compatibility?
Hi Guys,
I was planning to get these mounts and i actually called a subaru dealership to find out about them. The guy said these part numbers are from America and that he isn't sure if they are compatible with Australian Models. Just wanna clarify so it wont be a waste.
Part number: ST41022AS000 ENGINE MOUNT RH RH
Part number: ST41022AS010 ENGINE MOUNT LH LH
https://www.sti.jp/en/parts/subarubr.../ST41022AS000/
My Question is do you guys use STI engine mounts on your Australian 86/brz? If so where did you buy it from?
Cheers,
Feed
Feednamese is offline   Reply With Quote
Old 05-29-2020, 08:30 AM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Originally Posted by Feednamese View Post
Hi Guys,
Cheers,
Feed
Those will work fine. They aren't available from US dealers as far as I know. I think they are all imported here from Japan.
dragoontwo is offline   Reply With Quote
Old 05-31-2020, 09:47 PM   #3
Feednamese
Drives: 86
Old 06-14-2020, 09:00 PM   #4
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
Did the upgrade to my car and we’ll worth it BUT you should tighten up the entire driveline to get the full benefit. I know they’re harder than factory but I really can’t notice any difference. Then again I have the full drive line done so doing these and nothing else might be more noticeable!
Bodalenko is offline   Reply With Quote
'14 Engine compatibility with '13 chassis Snow27 Engine, Exhaust, Transmission 4 01-02-2020 11:00 AM
BRZ - GT86 Engine parts compatibility Hryasch Issues | Warranty | Recalls / TSB 6 08-19-2019 06:25 AM
WTB: STi engine mounts Joon525 Want-To-Buy Requests 0 10-22-2018 09:23 AM
FA20 Engine to ECU compatibility Gavmen Engine, Exhaust, Transmission 0 07-27-2016 07:35 PM
sti engine mounts, oem engine/tranny mount, oem radiator sickmint79 Engine, Exhaust, Bolt-Ons 0 08-08-2015 03:15 PM
