Old 05-28-2020, 02:49 PM   #1
norcalpb
norcalpb's Avatar
Rear brake pad size issue
Hello all, I just purchased Hawk DTC-30 front and rear brake pads.
I wanted to compare sizing with oem to make sure I ordered the right parts. My new front pads have the same surface area as stock, but it appears the rear pads are smaller in pad face length (pictures below)?
Since the pad is actually the same width it will cover the rear rotor no problem, but I wanted to know if this was normal before I install.
First picture is comparing to used stock, second is comparing to used Carbotech.
Rear pad part # HB671W.628
Old 05-28-2020, 05:14 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
As long as the backing plate is correct it should be okay. I have noticed this on the carbotech's I had too.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
norcalpb (05-28-2020)
Old 05-28-2020, 05:27 PM   #3
norcalpb
norcalpb's Avatar
Backing plate is the same size so I’ll try not to worry about it.
I know there are 2 different rotors for the front and this 2 different sized pads, but the rears are the same across all regions afaik.
Old 05-28-2020, 05:34 PM   #4
RayRay88
Drives: 2017 86 860 Special Edition
Rears are different too, Vented vs Non vented rear rotors. The non vented are 4mm smaller and 8mm narrower.
RayRay88 is offline   Reply With Quote
Old 05-28-2020, 08:03 PM   #5
norcalpb
norcalpb's Avatar
I can’t even find dtc-30 for the solid rear rotors
Old 05-29-2020, 12:55 AM   #6
RayRay88
Probably because it's limited to certain euro/asian regions. All north american vehicles came with the larger front and rear vented brakes. Hawk is an american/North american centric company. Some of the other international companies have listings for both and can make it confusing.
The Following User Says Thank You to RayRay88 For This Useful Post:
norcalpb (05-29-2020)
Old 05-29-2020, 03:37 PM   #7
norcalpb
norcalpb's Avatar
So I screwed up and saw last night that the brake pads I have currently in the rear are Hawk Street/Race which are a "street version" of the DTC-30 that I just freaking bought. They are the same compound.
Is it safe to run DTC-30 in the front, and Street/Race in the rear knowing they are the same compound and essentially the same pad? The only the difference is Street/Race has chamfered edges and a backing plate shim.
Front and rear brake pads size difference Tekno Virus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 11-21-2019 11:15 PM
E-Brake issue "clunking noise" when pulling the e-brake while rolling. Kinzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 06-20-2018 10:14 PM
Rear brake caliper banjo bolt size? ChrisD Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 04-22-2016 06:51 PM
BRZ/FRS big brake kit vs WRX counterparts: brake piston size (differences, if any)? mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-25-2013 12:07 PM
Font size issue GTB/ZR-1 Site Announcements / Questions / Issues 3 01-13-2013 09:22 PM
