Drives: 2014 FRS
2014 FRS with 56K kms, Odd transmission issue.
I'm hearing a faint sort of whining sound during cold starts,
When the clutch is pressed in, the noise goes away, when I take my foot off, it comes back. After a quick drive, the noise goes away. quick restart, the noise is not there. It comes and goes from day to day, the car is out of warranty period. Shifts gears without an issue, no odd noises |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
Throwout bearing.
Drives: 2014 FRS
#4 | |
The revised '17+ TOB (with the white dot) is the updated part and should remedy this issue. The part itself is around $30... the labor to replace it is equivalent to a clutch job unfortunately.
Drives: 2014 GT86
Yeah, cheap part .. to get to which one needs to drop gearbox.
![]() So hint1: always worth to change out cheap-ish TOB too, whenever you do clutch related or any work related to engine out/gearbox off, so as to replacement last longer. hint2: for twins worth getting updated TOB revision part number, which supposed to have improved lubrication, supposed to last longer. (IIRC toyota SU003-07349, subaru 30502AA150) |
Drives: 2014 FRS
here is a video, its hard to hear because it is soo subtle, but pretty much as described, a faint whining noise during cold starts goes away when the clutch is pressed in, also goes away after warms up or some driving. Thank you for your replies |
| Automatic Transmission TCU Issue | aa_chow | Issues | Warranty | Recalls / TSB | 10 | 08-06-2019 11:53 AM |
| Automatic Transmission issue- dealer is not recognizing the issue, please help! | Arrex | Issues | Warranty | Recalls / TSB | 36 | 06-03-2019 04:15 AM |
| Automatic Transmission Issue or ECU? | OpteronO3 | Issues | Warranty | Recalls / TSB | 8 | 09-15-2015 12:04 AM |
| Transmission issue P.S.A.... | 5AD86D | Issues | Warranty | Recalls / TSB | 10 | 06-22-2015 10:19 PM |
| Transmission issue | oppiee | Issues | Warranty | Recalls / TSB | 12 | 05-13-2015 04:11 AM |
