| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2014 BRZ Limited A/T
Differential Had Water
So I just changed differential fluids, and when i did, color was a very off-white cream which probably meant water ingress in the past when i drove through some floodwater.
In hindsight i forgot that maybe I should have flushed it first with extra fluid but I forgot to. So i just have two concerns: Will not flushing again basically contaminate my new diff oil and harm my differential? And i noticed my diff drain plug surface area was covered completely in metal powder. Ive been driving like this for about 7,000 miles. Was this a sign of significant damage? Sent from my iPhone using Tapatalk
not playing cards
Iron powder on the drain plug is normal. Magnet is there to collect the wear particles over the life of the diff.
I'd drive, drain, and refill for good measure. If the diff doesn't leak or growl, drive on happily.
As said change the fluid then check after 500mi. if still has white, do it again.
If it starts to clunk on and off throttle then there is a problem. |
| The Following User Says Thank You to ls1ac For This Useful Post: | Dave-ROR (05-24-2020) |
#4 | |
Thanks! Must be getting paranoid because i was running it this way for a good 9 months or more Sent from my iPhone using Tapatalk |
Drives: Q5 + BRZ + M796
I would do a flush, or use junk diff oil and change it several times over a month until the oil coming out looks water free then put in the good oil. The water probably caused extra wear, but what can you do about that now?
not playing cards
Shit, that's a long time. At least be prepared for the possibility of early failure. Keep listening to it and consider obtaining a spare from a salvage donor.
Drives: Subaru BRZ
Poor fucking design.. much like the brake calipers... I mean if the car is going to a country where floods are common you'd think that designer would install the diff away from the possible flood level.. stick it on the roof..
| The Following 5 Users Say Thank You to JD001 For This Useful Post: | Dave-ROR (05-24-2020), Opie (05-26-2020), Silviacrazed (05-24-2020), soundman98 (05-24-2020), Spuds (05-24-2020) |
Pft. Differentials can go a long time with water in them. It's not good for them, but it's not like water in an engine. Just change the diff oil and drive.
| The Following User Says Thank You to extrashaky For This Useful Post: | Tcoat (05-24-2020) |
Drives: hyper blue
cooling the diff quickly..ie quenching it in water, tends to suck water up the vent.
you might extend the vent line if standing water is typical. (transmission also.) |
| The Following 2 Users Say Thank You to thomasmryan For This Useful Post: | soundman98 (05-24-2020), Ultramaroon (05-24-2020) |
#10 |
Famous Potatoes
Drives: '15 ultramarine
I too would fill with fresh oil, drive a couple hundred miles, drain, lather, rinse, repeat until it comes out clean.
#11 | |
not playing cards
My diff makes a nice sucking sound when I remove the fill plug.
#12 |
ProCrastinationConsultant
wouldn't a thorough diff flush service do the same thing without the massive time sink of hundreds of miles of driving?
#13 |
Site Moderator
Drives: Stuff
This. Change it again for sure. Or just disassemble, clean it and lube it back up and just let it rip.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#14 |
Famous Potatoes
| The Following User Says Thank You to Sapphireho For This Useful Post: | Ultramaroon (05-25-2020) |
| Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover | mav1178 | Engine, Exhaust, Transmission | 5 | 02-11-2021 01:20 PM |
| Is my differential about done? | LotsaMiles | Engine, Exhaust, Transmission | 14 | 07-30-2019 09:31 AM |
| WTB: Differential | ArCha | Canada Classifieds | 3 | 02-27-2018 01:09 PM |
| WTB : Differential | ebphoto | Want-To-Buy Requests | 2 | 06-19-2016 01:46 AM |
| Anyone have a differential pop yet? | slicktop | Engine, Exhaust, Transmission | 6 | 02-26-2014 08:22 PM |
