Drives: 2019 PP BRZ
STI Short Shifter
Anyone here have the OEM STI short shifter? (C1010CA100). Already have mtec springs and shifter bushing installed and was curious to how would this compliment them.
Also already looked at IRP and Kartboy but wasn’t a fan of the rattling issues they have |
Wheels for Brains
I have the JDM TRD Short Shifter Column, MTEC shift springs, Perrin rear mount, and Cusco Trans Mount. Seems to work fine. Used to have the USDM TRD Short Shifter Kit and Whiteline Trans Mount before I swapped them out.
I think the short shifter was more suited to my driving preferences. Next to that, the most noticeable effects in feel probably came from the transmission mount and shifter springs. Gating effort is a little higher then the stock shifter, but it's hard to remember what stock shifter used to feel like. I've had the USDM TRD Short Shifter Kit on for 3 years until I switched to the full column a month ago |
Drives: 24 GR Yaris, 23 GR86
I do have JDM one (ST35010AS000 which I believe is no different to the USA model). Obviously feels good with mtec springs and shifter bushings but don't expect much - It's very subtle change. If you're after noticeably shorter throws this one might not be for you. Rattles happen with my unit too but usually around 6k RPM (stock one rattled more iirc)
#4 | |
Drives: 2019 PP BRZ
#5 | |
| How does the STI short shifter compare with the OEM shifter? | Ryan GT86 | Engine, Exhaust, Transmission | 7 | 03-29-2020 01:09 AM |
| 2017+ PP short shifter vs. STI short shifter | teabubblez | Engine, Exhaust, Transmission | 8 | 01-24-2019 12:16 AM |
| FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing | bergy | Transmission and Driveline | 8 | 10-20-2016 10:57 PM |
| kartboy short shifter and rear shifter bushing install and review. FR-S | UMB FR-S | DIY (Do-It-Yourself) Guides | 21 | 10-18-2014 02:41 AM |
| TRD Short Shifter Quick Shifter Scion FRS | hirollaz | Transmission and Driveline | 3 | 04-15-2014 02:24 AM |
