Old 05-14-2020, 04:56 PM   #1
Suparu
Drives: 2013 BRZ Limited
How to remove the fuel door?
I’m adding a new fuel door for some cosmetic flair but I can’t figure out how to remove the OEM fuel door. It looks like it’s riveted on. Has anyone here removed the fuel door before and know what size drill to use on the rivets?
Suparu is offline   Reply With Quote
Old 05-14-2020, 04:58 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
If it's cosmetic flair that you after, just break the OEM cover and then fix it backup using mosaic tiles and glass.. you'll get lots of flair for sure..
Old 05-14-2020, 05:36 PM   #3
Suparu
I wish you would’ve told me that before I dropped money on a replacement! Maybe I can mix some bedazzle with the mosaic.
Old 05-18-2020, 01:56 PM   #4
gtpvette
Drives: 2015 FRS - FFR GTM
I removed mine recently. I brought it in for paint matching. Yes those are rivets, I drilled them out. No problem. AS far as size,, you just want to drill out the head of the rivet then punch the rest out the back. You don't what to drill though the sheet metal. Try a bit about 2/3's the size of the head.
The problem is reattaching. I have a couple of rivet guns but couldn't get them in there not to mention I didn't have rivets as large as what's there. Ended up putting a riv-nut in there but had to rig the tool to extended it enough. Rivets are available via Toyota.
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following User Says Thank You to gtpvette For This Useful Post:
soundman98 (05-18-2020)
How to fix fuel starvation on left hand turns - Verus Fuel Door FT-86 SpeedFactory Engine, Exhaust, Transmission 3 08-21-2017 03:22 PM
How to remove gas door fantasista Cosmetic Modification (Interior/Exterior/Lighting) 1 08-28-2015 01:24 AM
how to remove door mirrors davebrus DIY (Do-It-Yourself) Guides 1 03-09-2014 07:39 PM
How to remove door panel? Mo707 DIY (Do-It-Yourself) Guides 3 02-19-2013 11:35 AM
Remove door handles? scyzer DIY (Do-It-Yourself) Guides 3 01-09-2013 03:08 PM
