Old 05-12-2020, 11:47 PM   #1
DrivingisReligion
Sleeper
Drives: WRB_BRZ
Wrap cat on ft86 catted UEL header?
I'm planning to wrap and DEI hi temp silicone spray my new ft86speedfactory UEL catted headers, question is, if I should wrap the cat? Or just wrap the pipes and leave the cat exposed but spray it with DEI spray when I spray the headers after wrapping?
Asking because I read somewhere, wrapping cat retains more heat in it.
Thanks!
DrivingisReligion is offline   Reply With Quote
Old 05-13-2020, 07:35 AM   #2
Gloonge
Drives: 2013 frs raven
The purpose of the wrap is to keep the heat inside the pipe and out of the engine bay. If you race the car and are chasing 10ths of a second then wrap the cat. If not then don't worry about it.
Gloonge is offline   Reply With Quote
The Following User Says Thank You to Gloonge For This Useful Post:
DrivingisReligion (05-13-2020)
Old 05-13-2020, 09:46 AM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Did you opt for the ceramic coating they provide?
Old 05-13-2020, 04:02 PM   #4
DrivingisReligion
Sleeper
Drives: WRB_BRZ
Nope. Ceramic coating only protects from the rust, a wrap actually keeps the temps down but there are chances of getting rust, which is a risk I'm willing to take.
Old 05-13-2020, 04:18 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Ceramic coating helps keep temps down too. Not as effective as wrapping, but it is effective. Most headers are stainless nowadays anyway so rust prevention isn't the issue that it used to be. I can't think of one that is not stainless anymore.
Old 05-13-2020, 05:22 PM   #6
Gloonge
Stainless is definitely not the same as rust proof. And header wrap definitely exacerbates that issue.
Old 05-13-2020, 05:23 PM   #7
Gloonge
Proper ceramic coating does work as a thermal insulator. Not the crap that comes in a can, but a local shop that does a baked on ceramic coating. It definitely carries a better finish and is leaps and bounds easier to maintain.
Old 05-13-2020, 06:09 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yes I am well aware. Most that I find are 304 and with hard running and header wrap you could easily put them into their transition temperature which also exacerbates the issue. I used to strongly be against header wraps on motorcycles since the extremely thin tubing they used would just disintegrate when you wrapped them after a couple years of hard use. You can hit it with a light pickleing solution which helps them out, since a lot of companies don't bother to properly passivate stainless parts.
Old 05-13-2020, 06:33 PM   #9
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
No point wrapping your cat. Just leave it alone. It's going to get hot as hell. As for wrapping in general, if you are worried about rust, the wrapping will retain the moisture far more than ceramic coating. Besides, as long as you are not sitting in traffic for hours in hot weather, it will be fine. Trust me, I've never worried about melting something in my engine bay in the middle of the 105 degree Texas summer. Plus in Florida is more humid and rains more frequently.
MS, CSCS, TSAC-F, CPT
Old 09-09-2020, 01:26 PM   #10
doku
doku's Avatar
Drives: 2017 Subaru BRZ w/ Performance Pack
I just bought some stainless uncoated headers for my car and I'm a bit concerned given the amount of heat protection that the stock headers have. So I decided to wrap the headers up to the cat in the DEI Titanium stuff which is basalt and not fiberglass. I'm not too worried about moisture since it rarely rains in Cali and I have the option not to drive the car when it does.
How many folks out there run uncoated and unwrapped headers? It seems to me it's like 99% of the youtube and pictures I see are just bare stainless.
2017 Subaru BRZ Performance Pack - Brembo Brakes - SACHs Dampers - Wedsport TC-105x 18x8.5 - Michelin Pilot Sport 4S 245/35 - STI Short Throw Shifter
doku is offline   Reply With Quote
Old 09-09-2020, 05:47 PM   #11
Interflop
Drives: 2013 Subaru BRZ
I'm not running anything on my JDL UEL header. The only issues I've heard with aftermarket UEL headers are coil packs failing under heavy track use which I think is more a problem with the UEL design and not the header itself.
Interflop is offline   Reply With Quote
WTB: FT86 Speedfactory Catted UEL header Dappur Want-To-Buy Requests 5 10-06-2019 04:58 PM
WTB FT86 Catted Header alphasaur Want-To-Buy Requests 0 11-12-2018 03:05 PM
WTB: FT86 Speedfactory Catted UEL Header hachigoku Want-To-Buy Requests 0 07-16-2018 09:56 AM
FS: FT86 SF Catted UEL Header SoCal stoked_on_spool Engine, Exhaust, Bolt-Ons 8 04-05-2016 11:29 PM
