Drives: 2013 frs
Hey everyone, IÂ’ve searched the forums for this issue and found things kind of similar but not quite what IÂ’ve got here.
I recently purchased a crashed Frs (front driver side). The work needed was minor just a fender a headlight and a turn signal light. I got those and threw them all in and everything appeared to work but IÂ’m having an issue I need to solve with the blinkers. I have to brake and light inspection this thing otherwise I wouldnÂ’t be bothered by it. So the passenger side is completely fine but the driver side front blinker wonÂ’t blink when the drl or headlights are on it just stays on (as a drl). The rear light blinks but front lights wonÂ’t. If neither Drl or headlights are on, the front light will flash. Not sure if itÂ’s related but passenger side flashes normally and driver side flashes quicker. I donÂ’t have led lights I have oem bulbs in there for now. Bulbs are brand new too. Any thoughts? |
| The Following User Says Thank You to Kappaisa For This Useful Post: | JesseG (05-07-2020) |
Drives: 2020 GMC Canyon Denali Diesel
You either have a bad bulb, or a short in the harness to the headlights. Pic's of damage before repair?
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Welcome to our forum, there, Kappaisa -
![]() I suggest you check the fuses if you haven't already done so. Oh yes, some of the guys on here may try to sell you some blinker fluid - just pay them no mind. |
Drives: 2013 frs
I have replaced the harness tidbit for the driver side as some pigtails were destroyed and eaten away but the wires were fine. I checked for power at each wire before crimping them together and looked at the wiring diagram to see which wires should put out which signals. I could not find a 4to3 pigtail that connects to the light socket anywhere so I used one off of a junked Yaris the only difference was the Yaris wire gauge was thicker than the rest of my harness. I doubt that causes significant issues after the current starts flowing. I hooked that up after finding which wires provide power to drl and which provide power while blinking.
I checked all fuses they are transmitting power when needed. Thanks for the blinker fluid heads up, I’ve got a few extra gallons in the garage I might flush and refill if I absolutely have to
OK, I'll call ol @Opie back, he is good with fixing up mashed up twins -
My knowledge ran out when they started having more that two wires per light circuit.
Drives: 2013 frs
Here are 2 pics of the sides to compare before I did anything wiring related.
So the 3 wires pulled out of the connector on the drivers side are either pinned incorrectly or were pulled so hard there is a short further back. I would double check that, and use a FRS harness (the red one) not a Yaris one. There may be a difference there. Let me know if you need any of the parts.
| The Following User Says Thank You to Opie For This Useful Post: | JesseG (05-07-2020) |
Drives: 2013 frs
Thanks for your response. I’ve had a bit of trouble finding the red 3 wire connector so I rummaged salvage yards for one that fit a 7444 light. I’ll double check the pigtails and see if I can follow the harness back and check for damage.
| The Following User Says Thank You to Kappaisa For This Useful Post: | Opie (05-06-2020) |
The quick flash is an indicator that the computer is seeing a load mismatch.
#10 |
Drives: 2013 frs
After following the wiring and looking at the loom the wires all seemed good. I took vintage readings every few feet to test if I had any changes anywhere. Nothing. Is1ac’s comment had me looking at all the lights and they all appeared to be functioning so I couldn’t put together why there would be a load difference on the driver side. I found out that the 7444 bulbs our blinkers use have 2 illuminating bands in them and one is brighter than the other. The way I wired the driver side had those bands flipped so my blinker was indeed working, but the blinker was on the low light band so it was grossly overshadowed by the brighter band that took power for drl.
After taking wires out and rewriring the 3 wires to properly illuminate each light band the problem was solved. No more rapid blinking and all lights behave as they should. I guess not having the proper colors for the 3 wire light socket (since it’s from a Yaris) set me up for a 50/50 shot at flipping the wires for the wrong light bands. thanks to everyone that helped! |
#11 |
Rice King
Did you check your blinker fluid?
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
| The Following User Says Thank You to Jordanwolf For This Useful Post: | soundman98 (05-10-2020) |
#12 |
Drives: 2013 frs
I did not, I was wondering if you recommend regular or synthetic.
| The Following User Says Thank You to Kappaisa For This Useful Post: | soundman98 (05-10-2020) |
#13 |
Check the flasher in the driver side area under the dash?
2013 Series 10 FRS #553
| Bizarre blinker issue, no LED lights | Kappaisa | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-04-2020 05:37 PM |
| iJDMTOY White/Amber LED Smoked Lens Side Marker Blinker Lights | afsefo | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 02-05-2018 01:22 AM |
| Bizarre BRZ radio rebooting | nalc | Electronics | Audio | NAV | Infotainment | 5 | 08-23-2016 10:24 AM |
| Issue with rear blinker | Turkish | Issues | Warranty | Recalls / TSB | 3 | 05-29-2014 03:52 AM |
| Blinker setting off hazard lights? | Sileighty_guru | Issues | Warranty | Recalls / TSB | 0 | 10-14-2012 07:54 AM |
