Old 04-28-2020, 08:11 PM   #1
romendiratta
Drives: White Scion FRS
Stiff Shifter Side to Side
Hey Everybody,
I'm fairly new to cars and I been having an issue with my shifter. The car is still drivable, but the shifter feel is very weird. If I push the shifter to the either side it shifts with ease, except when I try to shift into gears on the opposite side. For example if I start and move through gears 1-4, the shifter gives resistance when going into 5-6. If I am in gears 3-6, and I try to downshift to 1-2, the shifter gives resistance. I know that the shifter and linkage most likely needs to be lubricated, but I'm not sure of how to do that. Does anyone have any thoughts?
Thanks!
romendiratta is offline   Reply With Quote
Old 04-28-2020, 08:13 PM   #2
vladniko86
vladniko86's Avatar
Drives: FRS
The car itself comes with a particularly tight/stiff shifter. Try to compare to anyone’s nearby, yours is more than likely fine.
vladniko86 is offline   Reply With Quote
Old 04-28-2020, 08:17 PM   #3
romendiratta
Thanks for your response!
I have checked against another 86 and my shifter definitely gives more resistance.
Old 04-28-2020, 08:19 PM   #4
vladniko86
vladniko86's Avatar
Drives: FRS
Do you have a brz or frs? My frs compared stock to stock to a brz is way tighter
Old 04-28-2020, 08:23 PM   #5
romendiratta
I have an FR-S. This may play a role in the tighter shifter, but I don't think that that the difficulty to go into a gear should change as I drive. If I am in 6th gear and come to a stop. It is harder to put into 1st gear. If I am shifting into 5th after going 1-4, it is also harder for some reason.
Old 04-28-2020, 08:24 PM   #6
vladniko86
vladniko86's Avatar
Drives: FRS
What climate are you in?
Old 04-28-2020, 08:25 PM   #7
romendiratta
I'm up in the Midwest, so the car does sit during the winters.
Old 04-28-2020, 08:30 PM   #8
vladniko86
vladniko86's Avatar
Drives: FRS
Hmmm I only get that hardness going into 1st and reverse when it’s cold and the trans oil hasn’t warmed up yet
Old 04-28-2020, 08:33 PM   #9
romendiratta
Yes, I also get that as well. But the stiffness that I'm referring to occurs at all times when I drive the car.
Old 04-28-2020, 08:33 PM   #10
vladniko86
vladniko86's Avatar
Drives: FRS
Hmmm sorry can’t help ya. Have you done any work to the transmission?
Old 04-28-2020, 08:35 PM   #11
romendiratta
Nope. Thanks for your input though. Hopefully someone else can give me some advice on how to lubricate the shifter.
The Following User Says Thank You to romendiratta For This Useful Post:
vladniko86 (04-28-2020)
Old 04-29-2020, 01:12 AM   #12
Ultramaroon
not playing cards
Ultramaroon's Avatar
Is your shift linkage sticky moving fore and aft? Not being centered that way in neutral can cause the resistance you feel side to side. If it's not that, then the problem is likely internal to the transmission.
Old 04-29-2020, 06:46 AM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
In many of MT twins when gearbox/oil is cold, it's 2nd that is hard to engage until one warms it up in eg. 5min driving. Wouldn't worry on this.
Also, from not to worry things would be when driving at >5kmh, "hard to downshift from 2nd to 1st". IIRC it's by design, to prevent "money shifts". If one needs to downshift to first from second, while still going relatively fast (20-50kmh), better do throttle blip on downshift, for rev-match.
vladniko86: If it's 1st or 2nd, that hard to get in, my bet is that it's not that "common trait", but rather something else, most probably - slight clutch drag.
I'd check, if there isn't done some clutch pedal travel adjustment mod, and maybe revert it a bit, so that there is at least 1-2cm of "dead travel" before bite point.
as for OP, romendiratta: if you have it much harder to engage in compared to other twins, and it still seems too much resistance, i'd first try also if it's not clutch drag at fault, as it's relatively simple to adjust clutch pedal, and if not, maybe oil change. Regarding oil change, shifting feel might be made worse both by overfilling and underfilling, so worth ensuring car is level, when changing gearbox oil, as IIRC level is decided by filling hole (OEM: 2.2lr API GL-3 SAE 75W-90 | Toyota Genuine MG Gear Oil special II. I'm using Redline MTL GL4 70W80). How old is your car? If new enough and there is warranty, i'd also try to take it to dealership. If it's hard to get in gear, usually is because synchros not doing for whatever reason their job well. If it's old car you bought used and clutch drag is not at fault, i wonder if maybe synchros are worn?
Old 04-29-2020, 10:30 PM   #14
romendiratta
Hey guys, thanks for the input.
So there is no resistance when shifting forward or aft. The car is a 2013, but it only has 38k miles on it. I would assume that the synchros are still in good shape. Also I don't ever downshift into 1st. I'm not sure that I described the problem well enough. So I'll link you to this video to hopefully show you in more detail.
https://drive.google.com/file/d/1oW1...ew?usp=sharing
Sticky shifter on left side Sonicp9 Issues | Warranty | Recalls / TSB 16 07-27-2020 02:23 AM
Stiff Shifter in Neutral oldlostcory Engine, Exhaust, Transmission 2 04-16-2020 03:32 PM
Shifter stiff and hangs godbiggy Engine, Exhaust, Transmission 13 07-13-2019 03:42 PM
MTEC Industries Stiff Shifter Springs for 2013-2014 BRZ & FR-S YURparts Transmission and Driveline 16 08-07-2014 11:31 AM
I need clear side marks white shark fin antenna also shifteck short shifter also Anthony7515 Want-To-Buy Requests 0 07-05-2014 11:21 AM
