Old 04-26-2020, 11:22 PM   #1
imprezive
Drives: 2017 BRZ - WRB - PP
SC Kit for reliability (Jackson vs HKS)
Daily driver + occasional AutoX + potenial very occasional track day (for fun, so probably would only push car to 95% and intersperse some 75%/cool down laps)
Want more HP, but honestly think either kit would be MORE than enough power for me. I really want simplicity and reliability in the FL heat. I'm willing to spend a little extra to invest in proper cooling/engine management, but it seems like every component you add it just increases the potential for failure.
Either kit have better history of reliability, especially in warmer climates?
If I was trying to be EXTRA cautious, would it be possible to use a slightly larger pulley to generate less PSI, but also put a little less heat, wear, and tear on the engine?
Of course, the other possibility would be to put that $5k to work on more NA mods (currently have header, tune, K&N drop-in+perrin intake tube). I just don't think that would get me quite to the power level I'm hoping for.
imprezive is offline   Reply With Quote
Old 04-26-2020, 11:25 PM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Jackson Racing by far. Also any sort of technical difficulties and and replacement parts would be easier with JR than HKS.
MS, CSCS, TSAC-F, CPT
Old 04-27-2020, 09:31 PM   #3
The Jackson Racing kit is more proven.
PM me to order. I can get you set up with everything you need to make it reliable.
Old 04-27-2020, 11:54 PM   #4
HaXx
Drives: jrsc_brz
^^^ do it, i buy from csg often,
JACKSON RACING l RALLYBACKER l FORGESTAR l FORTUNE AUTO l INVIDIA
HaXx is offline   Reply With Quote
Old 05-12-2020, 08:42 AM   #5
quixeger
Drives: 2019 6MT on CSG flex A w/SX2s
How soon is too soon (mileage)? I’m thinking very similarly to OP about power goals and heat. 6k miles on a 2019 model.
quixeger is offline   Reply With Quote
Old 05-12-2020, 06:39 PM   #6
86TOYO2k17
Drives: 2017 toyota 86
Never too soon
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
mrg666 (05-14-2020)
Old 05-14-2020, 02:05 PM   #7
J1Avs
Drives: 2018 BRZ tS
Did mine within the first 4,000 miles of my 2018 tS. Get it done while the engine is young and healthy, and keep treating it well with regular fluid changes.
J1Avs is offline   Reply With Quote
Old 05-14-2020, 02:49 PM   #8
Decep
Drives: 2013 FR-S Series 10
look into the edelbrock too, there have been a few reports of failed rotrex units on here.
not that the edelbrock is perfect but replacing a bypass valve now and then isnt the end of the world
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following User Says Thank You to Decep For This Useful Post:
GrabTheWheel (05-19-2020)
Old 05-14-2020, 03:00 PM   #9
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I think a centrifugal kit works better for stock engine. Reducing the amount of low end torque is critical to prolonging the life of the engine on stock rods
The Following User Says Thank You to DarkPira7e For This Useful Post:
mrg666 (05-14-2020)
Old 05-14-2020, 03:31 PM   #10
mrg666
pessimistic skeptic
mrg666's Avatar
Don't forget that you will void the powertrain warranty which runs 60 months/60,000 miles. I was out $4500 to replace valve springs with JRSC. I am just pointing this out to make people aware of the additional expenses that can come up. But ... I still don't regret installing supercharger it was worth even $10K expense.
Old 05-14-2020, 03:36 PM   #11
Decep
that's true, but it's pretty easy not to floor it at high loads and at too high a gear. not a big deal.
That bump in mid range torque starting at 2500 rpm is just so, so nice for daily driving.
RCE SS-1 Coilovers
Corsa Catback
Old 05-14-2020, 05:26 PM   #12
DarkPira7e
DarkPira7e's Avatar
That bump is mid/low range torque is exactly why it's not easy to avoid flooring it. Unless the driver is highly disciplined of course. Most people aren't and only day they are
Old 05-14-2020, 05:41 PM   #13
Decep
Fair enough, but if you are dropping absolute minimum 5K on a supercharger, chances are you are an enthusiast and will know better. Unless you're a kid playing with mommy and daddy's money or whatever.
I haven't seen that many instances of bent rods on the 260ish hp power levels you get with these systems (before you go nuts and start adding smaller pullies etc). Nor has my mechanic/tuner fwiw.
RCE SS-1 Coilovers
Corsa Catback
CSG Mike (05-15-2020)
Old 05-15-2020, 05:22 AM   #14
MilkyWitness
Drives: fdsgh
asdf
MilkyWitness is offline   Reply With Quote
Jackson Racing Super Charger Rotrex Reliability Poll motomaster132003 Forced Induction 54 08-29-2020 10:19 AM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Turbo Reliability VS Supercharger reliability KGB Forced Induction 130 09-08-2015 09:55 AM
FI Reliability pheonixone Forced Induction 42 02-22-2015 12:51 PM
