Drives: 2005 Toyota Camry
PP Sachs shock assembly pictures -- anyone have it?
I've been searching for some time, and I am trying to get clarification...
Are the Sachs dampers on the Performance Package the same dimensions as the regular shocks? Specifically, the front struts, are they the same? I know the STI dampers are different than regular BRZ Showa shocks. The STI dampers are same as the Showa Tuning Evolution series, and (most likely) are probably both made by Showa. Any help is appreciated. Alex |
Drives: 17 BRZ
Took this yesterday. Showa and Sachs side by side
| The Following User Says Thank You to Espi For This Useful Post: | mav1178 (04-25-2020) |
Loading...████████] 99%
Drives: #0517
Are the PP dampers slightly longer at the bottom?
R1 3 5
╘┼┼┤ . 2 4 6 |
Drives: FR-S Whiteout
looks the same total length but the strut mount flange is a different design so it looks longer.
Intent > Content
cowardice is the mother of cruelty. |
Thanks for the pic.
| The Following User Says Thank You to mav1178 For This Useful Post: | Espi (04-25-2020) |
Drives: 17 BRZ
if i remember correctly its the same size.
| PP Sachs suspension vs tS Sachs supspension | FindOphion | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 05-24-2020 03:35 PM |
| Sachs PP Shock & Eibach Spring Combo - Roll Center Correction? | x_hawker | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 07-18-2019 02:41 AM |
| Adjustable Coilovers - Loose Shock Assembly and Spring Unloading | EndlessAzure | Issues | Warranty | Recalls / TSB | 14 | 09-27-2017 09:23 AM |
| Raceseng Shock Top - Rear Upper Shock Mount with 1” Increased Travel | RJasonKlein | Brakes, Suspension, Chassis | 2 | 01-18-2017 04:33 PM |
| What can you learn from a shock dyno chart? Or shock dyno 101 | Racecomp Engineering | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 30 | 03-01-2016 07:40 AM |
