Old 04-25-2020, 12:00 AM   #1
dholloway543
Software Hobbiest
Drives: 2015 FRS
EBCS Tuning OFT2
I have wired a boost controller to my cpc connector. For some reason it doesn't seem to work. I have boost going in the center of the EBCS.
if I plug the waist gate on one side it over boosts hard. I cut it at around 14psi and im targeting 12psi.
The other side is the normal waist gate. As if there was no boost controller
How do I set the vacuum lines and how do I wire the EBCS to the cpc? is the wiring directional?
This is my current tune setup. Is the tune the problem?
dholloway543 is offline   Reply With Quote
Old 04-25-2020, 02:03 AM   #2
steve99
Unfortunatlty there is no boost control hijack of the cpc solenoid for opensource tunes. Its only available in ecutek ( unless someone writes code for oensource.
if you want boost control woth opemsource you will need to buy am external electronoc boost controller and a mac valve
FS: OFT2 Open Flash Tablet V2 (SOLD) Asidrive Engine, Exhaust, Bolt-Ons 7 12-05-2019 09:58 PM
FS: OFT2 multistraddler Engine, Exhaust, Bolt-Ons 3 05-18-2019 11:11 PM
Delicious Tuning EBCS blueap2 Forced Induction 4 06-03-2015 08:35 PM
EBCS set up options Brick Software Tuning 17 04-13-2014 06:48 PM
EBCS vs MBC gdrider77 Forced Induction 17 02-05-2014 10:30 AM
