Old 04-17-2020, 06:49 PM   #1
dholloway543
Software Hobbiest
Drives: 2015 FRS
Longshot Question
Does anyone have any idea what cpu is in the FRS ECU?
or at least what cpu architecture it is?
denso appears to be using mips32 for most of their ecus. but im not sure if it is mips32
dholloway543 is offline   Reply With Quote
Old 04-17-2020, 07:12 PM   #2
dholloway543
Software Hobbiest
Drives: 2015 FRS
If someone has a fried computer. I would greatly appreciate it if you could take it apart and take a picture of the main board
Old 04-17-2020, 07:52 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
Out of interest what are you trying to achieve?
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-17-2020, 08:03 PM   #4
dholloway543
Software Hobbiest
Drives: 2015 FRS
I want to convert the bytecode to assembly and reverse engineer it back over to c. That would help everyone out. Right now I just need to know that architecture the CPU is to do that first conversion.
Mips32 assembly works about 80% of the time so it's hard to tell if it is right or not.
Old 04-18-2020, 03:05 AM   #5
makinen
makinen's Avatar
Drives: Toyota 86
Hitachi Renesas SH72531
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 04-18-2020, 08:26 AM   #6
steve99
https://www.ft86club.com/forums/showthread.php?t=68328
If your serious about reverse engineering code talk to the guys at www.romraider.com and a guy called td-d on that forum of he's still arround
Old 04-18-2020, 08:29 AM   #7
steve99
I've got 2 spare Woking ECU, also if you want the wiring to get it running on bench to you can flash it and log .message me.
You can buy used ecu for about $100 on eBay
They are also easy to swap in\out
https://www.ft86club.com/forums/showthread.php?t=102810
Old 04-18-2020, 12:07 PM   #8
dholloway543
Software Hobbiest
Drives: 2015 FRS
Okay thank you for all of the help and at some point i would need an ECU to test but that is going to be up the road.
Old 04-18-2020, 12:51 PM   #9
dholloway543
Software Hobbiest
Drives: 2015 FRS
https://www.renesas.com/us/en/doc/pr...b0051_sh2a.pdf
pages 70+ are why i needed to know the cpu architecture
Old 04-18-2020, 04:33 PM   #10
dholloway543
Software Hobbiest
Drives: 2015 FRS
Its definitely under progress, if you would like to follow the progress
https://github.com/reverseslayer/Renesas-disassembler
Alignment Shop in SD and quick question question JohnTran619 Southern California 5 11-21-2018 01:40 PM
Turn Signal Relay Question (Dumb Question) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 3 06-23-2017 01:58 AM
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
OZ question nosi9frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-27-2013 08:45 PM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
