Old 04-05-2020, 10:10 PM   #1
Masada
Recommendation for LED H1 Headlight bulbs
Hello,
I have Spec - D Headlights and I've run into an issue. I believe one of the bulbs is broken (the wire inside the halogen bulb moves around)?
I was looking around on the internet and it seems H1 bulbs are made for fog lights. Can these be used for projector headlights? Any I can find say they are not meant for low/high beams.
Also, with the Spec-D headlights, it has clips to secure the bulbs and are not a twist and lock. The reason I mention that is cause on some H1 lights they have a big fan on the back and the clips I don't think would be able to secure it.
Am I stuck with halogens or does anyone have any recommendations? Thanks.
Masada is offline   Reply With Quote
Old 04-05-2020, 10:47 PM   #2
Jdmjunkie
Drives: Scion FR-S 10 Series
I have had really good luck with Diode Dynamics.
Jdmjunkie is offline   Reply With Quote
Old 04-05-2020, 10:58 PM   #3
Masada
Unfortunatel, I don't see any H1 kits with Diode Dynamics on their site.
Old 04-06-2020, 12:38 AM   #4
Jdmjunkie
One of the people I follow on youtube reccomended these. Can't vouch for the quality but it is a neat idea.
https://www.boslla.com/product/bosll...-led-headlight
Old 04-06-2020, 12:46 AM   #5
Masada
Thank you for the link but one of my bigger concerns is fitment. On LED's the big fans in back, will it even fit or be secure when there are clips on the back and not rotating the hub to lock it?
Old 04-06-2020, 12:55 AM   #6
Jdmjunkie
I would think it would be fine, my Infiniti has jdm headlights in it and has 4 H1 bulbs for both hi and low beams. The clip will hold the bulb fine. All H1 bulbs are held in by clips why wouldn't it hold a led bulb? As long as you can get the clip secured I don't see an issue.
Headlight retrofit Recommendation SG02WRX Southern California 2 01-19-2020 11:38 PM
Headlight Bulbs phongtphan21 Cosmetic Modification (Interior/Exterior/Lighting) 4 07-31-2015 01:00 PM
OLM LED headlight bulbs bodayguy Cosmetic Modification (Interior/Exterior/Lighting) 30 07-21-2014 01:54 AM
FS: OEM Headlight and DRL Bulbs boredom.is.me Exterior Parts (Aero, Lighting, Etc.) 0 04-30-2013 07:18 PM
FR-S headlight bulbs? takethat Cosmetic Modification (Interior/Exterior/Lighting) 4 09-14-2012 03:11 PM
