Drives: 2014 BRZ Limited
Is it okay to run 255/40 front 255/35 rear?
I have a set of wheels all wrapped around in 255/40/18 but only two of them needs to be replaced
Ideally I want to have 255/35 all around but can i get away with just replacing the 2 bad tires with 255/35 and put it in the rear while keeping 255/40 on the front? When 255/40 wears down ill replace them with 35s... And lastly if im only gonna replace 2 tires should i put 35 front 40 rear? Or 40 front 35 rear? Thank you!!! Sent from my SM-G988U using Tapatalk |
Country Boy 4 Life
If budget is you only concern, then yes you can keep your old tires on the back and get new ones for the front.
If you care about the tires being the correct diameter, then the 255/40 is 5.7% larger diameter than oem. This is outside the generally accepted plus or minus 3% diameter difference that's allowable. Don't leave the taller tires on the front, it will look stupid. Many staggered setups have a larger diameter rear tire, though normally it's pretty close to the same as the front. Also, don't mix tire brands. There are a bunch of threads where people have, and their cars traction control turns on at the weirdest times. I mixed brands and experienced this. Meaning, buy two more of the tires you have just in the 35 series. Or, if you want different tires, bite the bullet and buy four matching tires. Good luck!!!
I LIKE TIRES! |
Rust bucket enthusiast
| Xp12 front(new) & rear. Rce sway bars front & rear, new front centric rotors. | dreamwonder | Brakes, Suspension, Chassis | 7 | 04-03-2020 05:51 PM |
| FS: AP Racing Sprint kit, OEM rear rotors and calipers, front and rear pads, extras | zdr93523 | Brakes, Suspension, Chassis | 10 | 02-15-2018 03:13 PM |
| FS: Racer X Rear LCA, Hotchkiss Front Bar, Raceseng 1" Rear Drop Mounts | Kuro86 | Brakes, Suspension, Chassis | 4 | 07-26-2017 03:01 AM |
| FS: Raybestos ST-43 front and rear pads. Front for Stoptech BBK, rear for stock | rever5e | Brakes, Suspension, Chassis | 1 | 03-16-2015 12:02 PM |
| SOLD. PADS for cheap:Hawk HPS front and rear + Carbotech XP10 Front and rear | Amalgamo | Brakes, Suspension, Chassis | 3 | 04-24-2014 07:22 AM |
