Old 03-21-2020, 08:42 PM   #1
graywzc
Drives: 2017 Silver BRZ PP
Do stock non-pp BRZ wheels clear 17+ BRZ PP rear Brembo
I'm trying to find two cheap wheels for drifting.
I have a 2017 BRZ with performance package. From this thread, it seems the non-pp BRZ wheel doesn't clear the bremo.
However, since I only need to put on two rear wheels for drifting, does the stock non-pp one fit rear brembo? If it doesn't fit, any recommendation on cheap drifting wheels?
graywzc is offline   Reply With Quote
Old 03-21-2020, 10:47 PM   #2
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
id hazard a guess you are fine for the rears. which is a good thing you can slap on a 225 on the OE's and let it ride. or a 215 if you want no bulge.
otherwise OE PP wheels are also cheap ish depending. I use a set for my autox and track day tires
Clutch Dog is offline   Reply With Quote
Help : Enkei RPF1 Clear STi Brembo's?? yoonjin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-19-2014 11:45 AM
Does anyone know if TSW Nurburgrings clear STI brembo's? SkAsphalt Wheels and Tires 0 05-14-2014 04:04 PM
Will stock wheels clear Wilwood BBK? Brody602 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 10:32 AM
Are the stock wheels clear-coated? Tromatic Northwest 2 07-29-2013 09:47 AM
Are the stock wheels clear-coated? Tromatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-17-2013 11:09 PM
