Old 03-10-2020, 11:46 PM   #1
smit666
Drives: frs
18x9.5 + 38 | 245/35/18?
i have a 2016 scion frs with skunk 2 lowering springs i was wondering if i could fit 245/35/r18 + 38 offset i also have 5mm spacers plz lmk asap.
smit666 is offline   Reply With Quote
Old 03-10-2020, 11:54 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Yes, with your 5mm , maybe even 3mm spacers in the front. The rear will fit no problem.
I LIKE TIRES!
Old 03-10-2020, 11:58 PM   #3
smit666
Drives: frs
no camber bolts or anything like that?
Old 03-11-2020, 12:06 AM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
If you are running OEM length studs, then I won't suggest anything more than a 3mm slip spacer. And with the specs you have for wheels, tires, and offset, you won't have very many millimeters in-between your tire and spring perch. You can add camber bolts, but won't be able to get much negative camber before you rub.
I LIKE TIRES!
Old 03-11-2020, 12:08 AM   #5
smit666
Drives: frs
would it be unsafe im turboing my car this weekend. plus i already bought the rims and tires :|
Old 03-11-2020, 12:36 AM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Some guys run 5mm on stock length studs. IIRC, you want eight threads minimum lug nut engagement.
Safety first
I LIKE TIRES!
Old 03-11-2020, 12:38 AM   #7
smit666
Drives: frs
so technically it should be safe?
Old 03-11-2020, 11:50 AM   #8
Leonardo
Country Boy 4 Life
Leonardo's Avatar
IMO, No. Though, a few members have said that they have done it for AutoX.
But, for me...
I installed extended studs when I added a 5mm spacer. So, I wouldn't do it.
This is why I suggested a 3mm spacer, which is generally accepted as the thickest slip style spacer to add to OEM studs. The 3mm should be enough to keep you from rubbing. And, the 2 extra mm thickness (of a 5mm spacer) will not let you add any significant amount of negative camber. You will need coilovers, with a smaller diameter spring compared to OEM, to be able to add enough negative camber to tuck the front wheels.
I LIKE TIRES!
churchx (03-11-2020)
Old 03-12-2020, 06:03 PM   #9
Shizuka
Shizuka's Avatar
Drives: 2018 BRZ PP (Modified)
Running that fitment, coilovers would help you a lot...
Shizuka is offline   Reply With Quote
Wheel Directory: Volk Racing TE37 18x9.0 +45 Front / 18x9.5 +40 OmegaKnight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-03-2016 08:09 AM
Wheel Directory: Avant Garde M240 18x9+30/18x9+20 NyC Zn6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-07-2015 03:24 PM
18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) Funky Fresh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-07-2013 09:52 AM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 01:52 AM
Wheel Directory: Volk Racing TE37 18x9.0 +45 / 18x9.5 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-04-2012 12:25 PM
