Drives: 13' Subaru BRZ
Coilover suspension recommendations for a wide body w/ Forced Induction
Hey guys looking to change up my suspension and wanted to get some input. Currently on Ground Control Suspension with KONI struts paired with 6.7k (375) 6 inch springs in the front and 6.3k (350) 7 inch springs in the rear. When going over small bumps I’m having issues with clanking/unsettling in the rear and occasional rubbing up front at full lock. The rubbing typically only happens after I leave the car parked in a position for an extended period of time and the springs settle. There is no preload on the springs at full droop in the rear so I assume I need helper springs?
Regardless I think my current suspension setup is a bit too soft. When contacting Ground Control Suspension they recommended switching to either a 500/550 setup or 600/650 spring rate setup. I’m also not sure if this would require me to re-valve my dampers. Considering switching to Fortune Auto 500 Coilovers and they suggested 7-8k front and 8-9k rear. I’m currently running a Rallybacker v1 wide body setup with 18x9.5” +5 wheels in the front w/ 255/40/18 and 18x10.5” -20 in the rear w/ 285/35/18 on General G Max tires. Along with this I also have a c38 Jackson Racing supercharger installed. I plan on mainly driving my car on the street with an occasional track day or HPDE each year. I’m not familiar with suspension tuning so any advice or suggestions are greatly appreciated. Not sure if I should just swap out for more aggressive springs and stick with my current setup or if I should just switch entirely. |
Why do you think your suspension is too soft for a mainly street car? Just asking.
- Andrew |
#3 | |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
He wants to keep his car at current ride height and try to eliminate some of the bottoming out/rubbing that happens while just driving on piss poor eastern PA roads.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
| The Following User Says Thank You to Soloside For This Useful Post: | Racecomp Engineering (02-24-2020) |
#4 | |
Adequate travel, spring length, and set up are crucial for any set up. Is the car really low? - Andrew |
#5 | |
https://www.instagram.com/diced_brz/ On another note, Thanks for answering my questions when I called a while back. I ended up getting my stiffer springs from you guys to solve the issue he's having troubles with. Went with 9ks all around on my KWv3s (Pretty sure it's at the maximum spring rate for it's valving)
2014 Subaru BRZ
Drives: jrsc_brz
im going rallyback v2 soon on a s/c brz, and in anticipation, i put in 9k/8k FA 500 coils and SPL rlca. i think 9k/8k is great for daily, ive had it on for a month or two and as far as comfort and ride quality, no complaints.
What made you decide on the stiffer springs up front?
Drives: jrsc_brz
#10 | |
If you want to go much lower, something like Fortune Auto would do the trick. Not as much total travel but it will let you get lower. They might require stiffer springs though. - Andrew |
| Forced Induction | James The Giant | Mid-Atlantic | 4 | 03-17-2017 12:00 PM |
| Forced Induction | OMJM | Want-To-Buy Requests | 1 | 12-01-2015 09:21 PM |
| Forced induction for ATs? | Lokutus | Forced Induction | 10 | 02-26-2013 03:42 PM |
| NOS or Forced Induction? | v3rgil | AFRICA | 1 | 11-08-2012 07:17 AM |
| 6AT (+) Forced Induction | RYU | Forced Induction | 18 | 09-09-2012 11:14 PM |
