Old 02-20-2020, 08:49 PM   #1
RyuHD
Drives: 2013 Subaru BRZ
ECUTEK Tuning Help
So i bought a Ecutek tune kit, and injected a tune rom file, but my car wont start now, ive tried going back but it does the same thing, is there a stock file i can put in it to start up again?
RyuHD is offline   Reply With Quote
Old 02-21-2020, 12:47 AM   #2
steve99
Ok soubds like you somehow flashed and incompatable tune file to your car or the flash process didn't conplete correctly.
Do you know your original ecu calid will be like ZA1JA01G
Do you know the calid of the tune file you flashed
Also what year is car and auto or manual.
Use ecutek go to program ecu but do a QUERY ECU. What happens does it tell you what your ecu calid is and does it say a ecutek licience is present in ecu ?
If you find this info above i may be able to help you
Old 02-21-2020, 08:21 PM   #3
RyuHD
ECU Cal - ZA1JA01C
I flashed ZA1JA01C file
Manuel
it says the ZA1JA01C on the top and a bunch more that supports it
Old 02-21-2020, 08:48 PM   #4
steve99
ECU Cal - ZA1JA01C
Manuel
If it. Cranks but doesnt start will most likey be map sensor doesnt match map sensor scaling in tune, see may other post in your other thread
Old 02-21-2020, 08:59 PM   #5
steve99
Also make surecthe injectprs fitted match whats in tune else it wont start either
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
ECUtek tuning for EL vs. UEL trippinbillies40 Software Tuning 1 04-15-2018 08:02 AM
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 02:37 PM
EcuTeK tuning available *BRZ & FR-S* Cotnoir Engine, Exhaust, Transmission 29 07-11-2012 07:15 PM
