Northern California NorCal
Old 02-12-2020, 06:27 PM   #1
Poncero1
Poncero1's Avatar
Drives: Scion frs
P2096 code
So I am ruining open flash and I recently got a code p2096 I thought I had a bad o2 I replaced it and it dint come back after 4 days now I am stuck done know what to do i run running the gt86 uel catter headers
Sent from my SM-N975U using Tapatalk
Poncero1 is offline   Reply With Quote
Old 02-25-2020, 04:44 PM   #2
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Perhaps reach out to Openflash and ask them to confirm the tune you are using is for the header you have mounted. Also ensure that you have no exhaust leaks at the header flange mounted to the block. Clear the code, Mount the tablet, monitor AFR when you're driving so you can see what is actually going on the next time that it comes on.
I've not had to deal with this code but I am running an OFT Catless UEL header and OFT, off the shelf tune.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
P2096 CEL Code week after installing header Inspir3dk Engine, Exhaust, Transmission 15 02-07-2017 11:07 AM
p2096 after headers install phantasticity Engine, Exhaust, Transmission 16 08-23-2016 07:23 PM
P2096, Completely stock. cbell7492 Issues | Warranty | Recalls / TSB 6 01-31-2016 10:10 PM
P0102, P0113, P2096 Engine code Oburn Engine, Exhaust, Transmission 24 09-22-2014 04:30 PM
CEL Code P2096 w/ exhaust only ShutterSpeed Issues | Warranty | Recalls / TSB 7 12-03-2013 12:59 AM
