Old 02-03-2020, 02:07 PM   #1
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
3 way Component Set - AMP of Head unit power?
I just picked up a 3 way component speaker setup (Focal 165 AS3's). Is it better to install these powered off the front speak power directly from the head unit, or to use the AMP power to the door speakers.
The speakers are a 4 ohm, 80watt rms 160 peak.
I know the AMP from the car is 140 peak (2 x 70watt) but is 2 ohms.
The Sony head unit I have is 25watt rms 50 peak per channel.
trying to figure out best way to power them until I can save up for a nice amp.
-B
( Speakers in question: https://www.focal.com/en/car-audio/c...t-kits/165-as3 )
HeresMyMind is offline   Reply With Quote
Old 02-03-2020, 10:55 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
i wouldn't bother installing them until getting a 6 channel amp to go full active and ditch the passive crossover.
no matter how you split it, if you install them now, it involves running wire, and then re-running everything again once the new amp is installed.
Old 02-03-2020, 11:21 PM   #3
HeresMyMind
They run off 1 crossover. I wired them to the front wires directly from the head unit.
It will be very easy to run a wire from a serrated amp to them when I upgrade. The crossovers are under the dash.
They sound fantastic and have so much bass. I can’t wait to throw some real power at them.
-B
Old 02-04-2020, 12:32 AM   #4
soundman98
soundman98's Avatar
Yes, they can work off the passive crossover. But they can work even better giving each driver it's own amp channel and custom crossover point.
I had significant previous issues with a passive crossover introducing distortion to the tweeters, so i avoid passives wherever possible. It's also much easier to set and alter the gains to change the output of specific drivers if they're not well matched for my ears.
HeresMyMind (02-04-2020)
Old 02-04-2020, 04:44 AM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Since you have an aftermarket head unit you can get away from powering off the head unit.
I wouldn't recommend going off the factory amp, 2ohms going into 4 ohms doesn't play well after a while.
As you said and soundman said wait till you save for a nice 4-6 channel amp. If you can.
FS: 2014 FRS Bespoke Head Unit w/ Navigation & GPS antenna / 2014 FRS Base Head Unit vitriumGTS Audio/Visual, Electronics, Infotainment, NAV 0 07-16-2019 03:02 PM
BRZ Head Unit with NAV dahincks Audio/Visual, Electronics, Infotainment, NAV 2 08-21-2018 06:12 AM
For Sale: Stock BeSpoke Premium Audio head unit with NAV unit Glok24 Audio/Visual, Electronics, Infotainment, NAV 13 07-22-2018 01:34 AM
Head Unit random reset/power cycle ? Breeeep BRZ First-Gen (2012+) — General Topics 6 06-03-2015 03:41 PM
Need help.. Pioneer head unit after power restored Skurj CANADA 4 04-06-2014 03:03 PM
