Old 01-22-2020, 04:13 PM   #1
Olegreg21
Drives: 2017 Asphalt 6spd 86
2017 86 "broken" valve spring
I bought my 86 in May of 2017. I've put 18k miles on it and at least 200 autox runs. Zero track days and only driven on weekends and to events. The car is full DS trim (only "power" mods are Nameless axle-back and K&N drop in). In November it developed a rough idle and eventually threw a code (don't remember the code), but the misfire was in cylinder 4. It wouldn't let me turn off tc or use my cruise. I took it to the dealership and they've had it since Nov. 18th. They said the injector was bad, it was replaced after waiting on parts and no resolution. They now say its a broken valve spring. Has anybody else heard of this on the newer cars? Should i consider getting rid of the car, i like it but i don't want to have issues every 18k miles.
PS I went to another dealership first and they said the valves needed adjusted and needed a re-tune. There was only one master tech there. He said it would take him a few months and he recommended a different dealer.
Olegreg21 is offline   Reply With Quote
Old 01-22-2020, 04:33 PM   #2
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I haven't heard of the issue in the newer model years.
For what it's worth, when I went FI I had a problem.
No rough idle but High Fuel Trims, threw a code, didn't let me use cruise or tc like you described. Turned out I had a vacuum leak. Patched it up and no problems since.
I would look into lemon laws in your state maybe.
Clueless
YamahaR86 is offline   Reply With Quote
Old 01-22-2020, 04:35 PM   #3
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
These cars are prone to coil packs going bad causing misfires (typically pre-2015 though), particularly cylinder 4. Try replacing that and see what happens.
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
DarkPira7e (01-22-2020)
Old 01-22-2020, 05:02 PM   #4
ka-t_240
What do they have that is leading them to think its a valve spring failure? I seem to remember there was some issues with something in the head on the 17s, you may need to look at some other posts on here for 17s with engine failures.
I have been tracking and doing auto-x on my 2013 since 2014. Rev Limiter is above stock, never had an issue with the valve springs.
ka-t_240 is offline   Reply With Quote
Old 01-22-2020, 05:03 PM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
So.. is the dealer fixing it? Should be warranty unless they have evidence of abuse (overrev, etc).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-22-2020, 05:13 PM   #6
kev0
Drives: '14
Do you know why only cylinder 4's coil pack failure is common for pre-'15 cars? The coil pack part number's are all the same, I sure.
I'm asking cause that's happening to me right now lol.
kev0 is offline   Reply With Quote
Old 01-22-2020, 07:29 PM   #7
Chuckable
Drives: 2017 Toyota 86
I can’t remember where I saw it, but I believe there is a TSB for certain VIN range 2017 models regarding valve adjustment. That may be something to research to see if it applies to your case.
Chuckable is offline   Reply With Quote
The Following 2 Users Say Thank You to Chuckable For This Useful Post:
ka-t_240 (01-23-2020), NoHaveMSG (01-22-2020)
Old 01-22-2020, 08:01 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
This.
There are multiple threads on newer cars that have valve adjustment out of spec. Same symptoms.
Old 01-22-2020, 09:36 PM   #9
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Where was the vacuum leak? Just curious...
sly is offline   Reply With Quote
Old 01-23-2020, 09:32 AM   #10
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Turned out to be the PCV valve. I had replaced it with the STI one but there isn't enough room for a wrench/socket in there to maneuver in.
Also in the earlier year cars, the evap hoses aren't clamped under the intake manifold so when I was diagnosing my leak I clamped those down as well. They blow off when you go FI.
Clueless
The Following User Says Thank You to YamahaR86 For This Useful Post:
mswbrz (01-23-2020)
Old 01-23-2020, 12:16 PM   #11
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
I had the same leak bro , my PCv just snapped in two and I wasn’t able to redline the car . Got that fixed and we good to go now .
In regards to the post , is the car under warranty still ? If so I would have the dealer who said it needed valve adjustment and time done print out that note from the dealer and then find the nearest biggest city near you with a dealership who has the most recalls done under their belt as a dealer and perhaps try there .
Lastly , I have 13 Brz and when I had issues with redline vacuum leak ect I changed the ignition coils aswell due to it saying I had a misfire in cylinder 3 after a particular delicious tune . My Brz has about 74,000 miles when it started saying misfire On cylinder 3 . After the pcv valve and coils were changed no more misfire , but I digress ....
Find a dealer to look at it perhaps don’t tell them anything just symptoms and see what they say ?
mswbrz is offline   Reply With Quote
Old 01-23-2020, 03:49 PM   #12
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
What year is your car? Pre 2015's had three different updates to the coil packs (all 3 have different part numbers) in 2015 they went to a 4th style and an updated engine harness & connector. You have multiple options to "fix" this depending on what year the vehicle is.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 01-23-2020, 03:58 PM   #13
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Looks like his is a 2014 FRS AT based on his profile.
Clueless
Old 01-23-2020, 03:59 PM   #14
Olegreg21
The dealer is fixing it under warranty. They said Toyota came in and looked it over and said it was a broken valve spring
The Following User Says Thank You to Olegreg21 For This Useful Post:
tomm.brz (01-23-2020)
2014 FRS broken valve spring = new motor whip Issues | Warranty | Recalls / TSB 12 05-28-2019 01:20 PM
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 04:20 AM
When I bought a "broken" car from another FT86Club member... dhuang FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 08-17-2017 04:39 PM
Gauging interest in "Mild upgrade" aka OEM+ spring/shock combo mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-10-2017 03:17 AM
Variable Valve "Butterfly" Exhaust dlux Southern California 19 02-22-2016 06:21 PM
