Old 01-06-2020, 11:07 AM   #1
ZDan
ZDan's Avatar
Drives: '23 BRZ
good NON-adjustable coilovers for road/track?
Spring rates in the ~5-7 F/~7-9 R range.
Do such coilovers even exist?
Adjustability costs me points and adds weight! ~40 lb. each for ride height adjustability and every dimension of damping adjustability.
Not averse to spending a few $$$ on good quality and revalving for desired spring rates.
Old 01-06-2020, 11:12 AM   #2
Racecomp Engineering
Bilstein B14, change the springs and possibly revalve as needed.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
solidONE (01-06-2020), Tristor (01-06-2020), ZDan (01-06-2020)
Old 01-06-2020, 11:28 AM   #3
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
Seconding Bilstein B14s and then running Raceseng CasCam camber plates in the front w/ Shocktop rears. Gets you full travel, minimal effect on roll center due to the camber plates, and gets much more and simpler camber adjustments in the front.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
ZDan (01-06-2020)
Old 01-06-2020, 12:34 PM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
Should have gone into current setup:
Swift BRZ Sport springs (3.8F/4.5R)
Raceseng camber plates
Stock PP/Sachs dampers, with bumpstops cut down from ~60mm to ~25mm
This setup is semi-OK at the track, but on the street the loss of front bump travel is intolerable. The Swift BRZ Sport springs lowered the car 1.5" front and 1.25" rear, I added in 1/4" spacers to the front upper spring seat to give -1.25" all around. Note that Raceseng camber plates cut significantly into bump travel, ~15mm IIRC from measuring.
At the track the lack of front bump travel helps to minimize roll during cornering but gives mid-corner understeer which is tolerable at most tracks but sucks at Palmer CW Turn 4...
Would like to go stiffer on spring rates all around while increasing front bump travel significantly.
Old 01-06-2020, 12:49 PM   #5
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Sorry I know I'm not contributing to this, but it's it normal practice to cut the business bumpstops? I have SACHS dampers also.
Drifter X is offline   Reply With Quote
Old 01-06-2020, 01:34 PM   #6
wparsons
wparsons's Avatar
Most lowering springs either include new ones, or include instructions on where to cut the stock ones.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 01-06-2020, 03:33 PM   #7
Tristor
Tristor's Avatar
With being down only 1.25" in ride height, if you're on the bump stops that often I think that's indicative you need higher spring rates and a damper valved for those rates. It'd be probably be worth investigating Bilstein B14 and getting it custom valved so you can run 6-7k springs in the front and maybe a little higher in the rear, depending on your tires and aero.
Are you running any aero? It can have significant impact on the necessary spring rates.
I'm not sure who all the tuners for Bilsteins are, but I've heard good things about FCM.
Old 01-06-2020, 04:12 PM   #8
Lincoln Logs
Lincoln Logs's Avatar
Drives: #337 2017 Toyota 86
Extended shock mounts do not magically give you full suspension travel. You trade droop travel for bump travel.
If you are wanting a non adjustable coilover, I would personally stick with camber bolts and factory top hats to reduce NVH.
Lincoln Logs is offline   Reply With Quote
Old 01-06-2020, 04:19 PM   #9
Tokay444
Penske will build you whatever you want.
Old 01-06-2020, 05:22 PM   #10
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Or have a word to 949Racing. I think they will build you a non-adjustable damper to what ever specs you like.
ZDan (01-06-2020)
Old 01-06-2020, 06:16 PM   #11
ZDan
ZDan's Avatar
Drives: '23 BRZ
Issue seems to me to be upwards of 2" lost due to lower + camber plates combined with lack of bump travel with the factory Sachs dampers.
I do want more spring stiffness to minimize roll at the track.
But I don't think that will help regarding bottoming the fronts over bumps on the street.
Seems like a solid option, might try them as-delivered damping rates and maybe something like 4.5k front 5.5k rear springs...
The springs they come with are progressive at 2.5/4.5 front, 3.0/7.0 rear.
Come to think of it I'd probably just try them with as-delivered springs first anyway.
But at that point it might make more sense to just run the current 3.8F/4.5R springs and Raceseng plates with B6 or B8, hoping they have significantly more bump travel vs. factory Sachs. Softer springs than desired, but -40 lb. for no height adjustment!
No aero.
Old 01-06-2020, 06:22 PM   #12
ZDan
ZDan's Avatar
Drives: '23 BRZ
- Andrew
Ha, just saw this! Yeah, that seems a solid option, or as said above compromise-rate linear springs with "stock" B14 damping. But again at that point might just consider B6/B8 with existing 3.8/4.5 lowering springs...
Old 01-06-2020, 06:34 PM   #13
strat61caster
strat61caster's Avatar
B14 lower perch is for 60mm ID springs, make adapters or replace top hats to use any 60mm spring you want. You might save a few bucks up front on the B6s but as soon as you bore of the 90mm springs you're looking at sleeves or fab work.
ineedyourdiddly
Old 01-06-2020, 06:54 PM   #14
B6 are roughly the same bump and droop travel as stock. B8 have less droop. They may have shorter bumpstops but that's it. Good shocks but don't buy them for more travel!
Certainly could try the B14s as is and go from there. I'm sure 5k/6k would be good on standard valving, 6k/7k maybe a little underdamped in front. I do have Bilstein branded 7k springs if you're interested. Edit: and KW branded 5k 200mm springs if you want to create a German Frankenstein's monster. Lol. Obviously there are tons of other choices, we were just doing some shop clean up today
The raceseng plates work much better for coilovers if I recall. With their upper perch the stack height is small and you don't lose bump travel, but you'd have to buy that from them.
I would not recommend 2 inch drop rear mounts.
I would expect the coilovers set up with proper travel to be a large improvement in driveability over your current set up.
- Andrew
Tristor (01-07-2020), wparsons (01-07-2020), ZDan (01-06-2020)
Ohlins Road and track coilovers Lithium Brakes, Suspension, Chassis 7 07-29-2017 04:20 PM
FS: Ohlins Road & Track Coilovers Wuuu Brakes, Suspension, Chassis 10 03-16-2015 09:37 PM
Ohlins Road & Track Coilovers for sale h4nh Brakes, Suspension, Chassis 17 02-18-2014 11:35 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 04:11 PM
