Old 12-29-2019, 02:23 AM   #1
LOW_and_SLOW
Drives: 2017 BRZ Crystal Black Silica
Ecutek or oft
I decided I’m gonna go for the sbd kit, which ecutek should I get for tuning and can I get away with just the oft tablet for this turbo setup?
I’m stock block right now so I’m just trying to aim for 260-70ish whp.
Someone drop some knowledge.
LOW_and_SLOW is offline   Reply With Quote
Old 12-29-2019, 04:56 AM   #2
tomm.brz
Drives: brz 2017 hksv2
ecutek is so much better for turbo, you have everything you need for perfect boost control
Old 12-29-2019, 06:07 AM   #3
jRuN
Just curious, what is OFT missing for turbo applications? And furthermore, is it impossible for them to add those missing functionalities? Seems I always hear ecutek is better for turbo... If I was responsible for the oft brand I'd be looking to close the gap on those missing features.
Sent from my Pixel 3a using Tapatalk
jRuN is offline   Reply With Quote
Old 12-29-2019, 06:32 AM   #4
steve99
For lower boost applications your fine with oft say up to 10psi or so.
When you go higher boost or want electronic closed loop boost control then ecutek wins out.
Ecutek overboost protection is also better
Ecutek also supports flex fufel on all models oft only supports pre facelift ie pre 2017 for flex.
Ecutek also has full time closed loop fuel control
Ecutek also has intergrated speed density for higher boost applications.
The main difference is that with oft your altering the tune tavles in a standard rom, ie standard ecu programing. Where with ecutek they add a wgole bunch of additional prpgram\software to the ecu to do stuff like boost control, over boost prptection map switching, flex, speed density , closed loop fuel control and more
http://www.ft86club.com/forums/showthread.php?t=106068
gt7877 (12-29-2019)
Old 12-29-2019, 12:06 PM   #5
LOW_and_SLOW
So I would have to buy the ecutek pro ecu programming kit if I’m going this route?
Old 12-29-2019, 05:24 PM   #6
steve99
Yes if you want to flash tunes yourself or do a remote tune with tuner you will need your own pro ecu cable or kit.
You eill also need am ecu licience amd tune see here
http://www.ft86club.com/forums/showthread.php?t=117520
FS: Ecutek ZaneRL9 Engine, Exhaust, Bolt-Ons 12 05-24-2016 07:47 PM
FS Ecutek SubaSteve Engine, Exhaust, Bolt-Ons 7 03-25-2016 08:22 AM
ECUTEK FR-Shred Want-To-Buy Requests 1 06-13-2015 02:21 AM
WTB ECUtek. YEAHdams Want-To-Buy Requests 0 04-09-2015 11:54 PM
Ecutek's 86 jpit FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 07-12-2013 12:35 PM
