Drives: 2015 BRZ
Crawford Power Blocks idle issue
First post on this forum, I got the Power Blocks with the Grimmspeed CAI and Openflash tuner. I started my car and it would rev up and down through 1k and 2k rpm, bogging down when it gets below 1k rpm, and shuts off after around a minute. Im on the Stage 1 tune and I flashed it when I put the CAI on. All the PCV hoses are attached and everything is plugged in correctly from what I could see.
Drives: 2017 BRZ PP , 2005 Saab 97X
Id recheck everything. it sounds like your idler control isnt functioning right so you got a leak someplace.
otherwise try adjusting the tune for the power block spacers. https://www.ft86club.com/forums/showthread.php?t=71285 |
Drives: brz 2017 hksv2
upload a log or can t help
did you rescale maf after installing CAI? but yes i would also think of a leak, check also the hoses under manifold |
#4 | |
Drives: 2017 toyota 86
Based on that it would be a lot easier. But my guess you pinched a gasket or it dropped/fell out and you got a bad vacuum leak. |
Drives: 2015 BRZ
UPDATE: Found the problem, the gasket on the driver side of the manifold slipped when i put the blocks in, and when I tightened the bolts down, it must've cut the gasket. Ive already ordered new gaskets. Thanks for help
| Tags |
| crawford billet blocks, idle problem |
| e85 and Crawford power blocks | Lantana frs | Engine, Exhaust, Transmission | 10 | 07-21-2018 11:34 AM |
| Crawford power blocks | Lantana frs | Software Tuning | 2 | 10-11-2016 09:54 PM |
| Crawford Power Blocks | absolute | Engine, Exhaust, Bolt-Ons | 3 | 05-17-2015 11:21 AM |
| Crawford power blocks fs | Triumphrider | Engine, Exhaust, Bolt-Ons | 2 | 04-06-2015 11:17 AM |
| Crawford Power Blocks like new | oTaGGeDo | Engine, Exhaust, Bolt-Ons | 0 | 07-27-2014 09:22 AM |
