Old 12-24-2019, 08:36 PM   #1
Rabrooks
Rabrooks's Avatar
Drives: 2020 Subaru BRZ
Transmission Swap. Need help
. I have a 2013 FRS with auto trans. I have purchased a good bit of stuff to perform the swap. I was told I needed a donor wiring harness from the engine bay and from the dash, along with ECU and BCU. Can someone elaborate why I need the harnesses. Seems it would be easier to just add in whatever wiring is missing rather than a full wire swap.
One of the reasons for this question is because I started the wiring swap. Then realized the donor harness doesn't have a connector for one of the components just to the right of the throttle pedal. After investigation of the harnesses I discover there was a running model change to the electrical system. Original system went from late 2012 til 5/13. the new system went from 5/13 to somewhere near current. Guess when my car was manufactured. Yep you guessed it. 5/13.
I would love to get good schematics from both systems if someone can direct me to the best place to get such a thing. Hopefully someone here has a real schematic.
Thanks in Advance
Roger
Rabrooks is offline   Reply With Quote
Old 12-25-2019, 12:06 AM   #2
Stomachbuzz
Drives: 2013 FRS
You can always rig up your own 'harness' but it's much easier to use a factory harness [adapter].
The reason you would need the appropriate harness when doing a transmission swap is because the M/T and A/T do not use the same wiring/plugs.
The A/T will have many more plugs for the additional electrics inside the valve body and such. M/Ts typically only have a few plugs for shaft speed sensor, reverse lights, and I guess shift lever position on these cars.
You might think "ok, well, I'll just use the A/T harness but cut off all the unused plugs."
The M/T will have less plugs/connectors than the A/T, but the plugs they share in common likely are not the exact same connectors. Unlikely they will smoothly plug in and you can just tie the excess off with a few zip ties.
You can find the appropriate harness, or you could technically hack your own together just using single wires per pin that you bind together.
Stomachbuzz is offline   Reply With Quote
Old 12-31-2019, 08:22 PM   #3
Rabrooks
Rabrooks's Avatar
Bump for more help
Thanks
Transmission swap or gear set? wrxgoose Engine, Exhaust, Transmission 9 09-25-2018 01:21 PM
Transmission swap assistance wrxgoose Engine, Exhaust, Transmission 2 10-23-2017 07:17 PM
Transmission swap Wilfred86 Engine, Exhaust, Transmission 6 10-04-2016 04:22 PM
Transmission swap ChrisD Engine, Exhaust, Transmission 6 04-04-2016 09:27 PM
transmission swap? VJZNAV Southern California 1 03-26-2014 11:57 PM
