Old 12-20-2019, 10:30 AM   #1
MotoX16
MotoX16's Avatar
Drives: 2017 Subaru BRZ
High STFT At Idle
Hey Guys,
Having some issues with my tune right now and after a few revisions with my tuner the fuel trims at idle are still pretty high (15-20%). Looking for suggestions.
FBM turbo kit. I have looked over all the intake piping and cannot find a leak. Manifold pressure at idle is around 0.32 bar, vacuum at idle is -19 mm/Hg, which from what I've read on here is normal.
The trims look a lot better under light throttle and cruising around, really just having the issue at idle. I'm leaning towards and exhaust leak, but this issue only popped up after I adjusted/tighted up my IC piping right before the throttle body.
Front O2 sensor is relatively new and maf sensor was cleaned recently so I think I can rule those out.
I'm trying to spend as little time laying on my freezing garage floor as I can so any help is appreciated. TIA
https://datazap.me/u/motox16/1212-idle?log=0&data=30
MotoX16 is offline   Reply With Quote
Old 12-20-2019, 01:38 PM   #2
tomm.brz
Drives: brz 2017 hksv2
Then maybe you had an intake leak before tightening the IC and you just need now an updated Maf scaling/SD VE scaling(if hybrid SD)
I usually see a bit higher engine load during warm idle, like 0.21 or a bit more at those rpm you are
You having only 0.17,i would just fix the maf scaling, I don't think you have a mechanical problem
Old 12-20-2019, 02:36 PM   #3
MotoX16
MotoX16's Avatar
Its very possible I had a leak before hand, but I have been working with my tuner since I made these changes. We've done 3 or so revisions since then and my stft's havent really changed at all, which is why I was thinking a hardware problem.
As far as engine load goes I have no idea why it would be different. I am definitely a bit of a noob when it comes to tuning, but I'm trying to learn more. I wouldnt say it was warmed up though, oil temps were only 110F
Old 12-20-2019, 02:49 PM   #4
tomm.brz
What I said about engine load, I was meaning that I think the actual maf scaling could be a bit low than needed
In fact STFT is trying to put more fuel
The Following User Says Thank You to tomm.brz For This Useful Post:
MotoX16 (12-20-2019)
Old 12-20-2019, 03:56 PM   #5
MotoX16
MotoX16's Avatar
Any idea why my maf voltage jitters around so much? Seems like 1.2-1.35V is a pretty big range to be jumping around in
Old 12-20-2019, 04:10 PM   #6
tomm.brz
Doesn't seem so problematic, it always tend to do so to an extend, also turbos could cause a bit of MAF fluttering I guess
gt7877 (12-24-2019)
Old 12-20-2019, 04:52 PM   #7
steve99
Do you have bigger port injectors ? If so check injector latency values
Anothe way round it willbe run 100% direct injection to about 0.4 load in pi\di tables
If that fixes fuel trims at idle once car warm then its likely port injector scaling\latency problem with the bigger injectors
gt7877 (12-24-2019)
High negative STFT and LTFT 86TOYO2k17 Issues | Warranty | Recalls / TSB 22 09-30-2025 03:10 PM
High Idle (up to 3k) while stopped in gear Eazy-V Software Tuning 23 01-24-2020 09:37 PM
high ltft at idle, my how to fix it(not fixed yet) trdric Software Tuning 16 06-18-2015 10:27 PM
Buzzing/Humming sound at high idle DGM.BRZ Issues | Warranty | Recalls / TSB 5 04-08-2015 08:04 PM
High coolant temp at idle with A/C off extrashaky Issues | Warranty | Recalls / TSB 11 11-11-2014 04:50 PM
